Fuel Additive for 2012 6.7 Cummins - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 09-06-2012, 10:12 PM Thread Starter
I have been reading the threads and most of them pertain to older diesel trucks. I just bought a new 2012 6.7L Dodge 2500 yesterday and hope to have years of fun with it. All of the threads seem to agree that an additive is needed with every tank of diesel. So I decided when I picked up my truck to talk to the head diesel mechanic at Dodge. He said that the new Dodges were built to run on the ultra low sulfer diesel fuel and no additive is required. He even went so far as to say that many of the additives could actually harm the engine or make it work harder to remove the buildup that the additives can cause. This is my first diesle vehicle so the contradicting points of view are very confusing. Yes or No to additives?
Thanks
Fishboy
Fishboy is offline
post #2 of 9 (permalink) Old 09-07-2012, 07:50 AM
Bcrocker01's Avatar
You beat me to it I also was wondering the answer to this question
Bcrocker01 is offline
post #3 of 9 (permalink) Old 09-07-2012, 06:01 PM
Diesel Filled Veins!
Sandman76's Avatar
No additives required. You may need an anti gel agent in cold weather if your fuel stations don't get to ordering winter fuel soon enough or a cold snap hits hard. I live where in winter -40* is fairly common and there's no gelling issues here but the stations have winter fuel by October. Diesel Power Service is what many recommend if you need an anti gel agent.
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #4 of 9 (permalink) Old 09-07-2012, 06:17 PM Thread Starter
Thanks Sandman76
I was leaning towards not putting any additive in with every fillup but there sure a lot of posts about needing it. Are they just needing it because of previous generations of the cummins engine not being built for the ultra low sulfer diesel and now the current diesel engines are built for the ULSD fuel?
Thanks
Fishboy
Fishboy is offline
post #5 of 9 (permalink) Old 09-07-2012, 06:43 PM
Sandman76's Avatar
The 2003-2007 5.9L Cummins seemed to have injector issues and sometime after 2008 Chrysler updated the filtering system on the 6.7L diesels. Before that the VP44 trucks were good on Low Sulfur Diesel but not Ultra Low Sulfur Diesel and many many VP44s broke (either from the ULSD, faulty lift pump or from a combination of both). I used to run two cycle oil in my 2001 so the VP44 was for sure lubricated and I used up the rest I had in my 2008 but now I run nothing. The fuel suppliers have wisen'd up and started adding lubrication to ULSD but I don't know when they started doing that. So no worries about lubrication. If you REALLY want, you can do a cost analysis on additive and see if even doubling the life of your CP3 is cost effective even if adding something to your fuel would double the life expectancy (which I doubt highly). Better money is spent on filtering your fuel and oil if you really want life expectancy out of your injectors and CP3 injection pump and the engine in general. Yes, filtering costs, but not as much as the alternative.
post #6 of 9 (permalink) Old 09-07-2012, 06:43 PM
Some people think you need it because some people say you need it because some people use it.
012cummins is offline
post #7 of 9 (permalink) Old 09-07-2012, 07:09 PM
Sandman76's Avatar
Lemings
post #8 of 9 (permalink) Old 09-07-2012, 09:13 PM
jam1on1's Avatar
i use fppf total power or there polar power have had no problem in over 5 years
2014 megacab 2500 longhorn ,2013 t/c van, 2014 bighorn fifth wheel 2011 dodge charger rt
jam1on1 is offline
post #9 of 9 (permalink) Old 09-07-2012, 10:50 PM
Sandman76's Avatar
It's not about having problems or not having problems, it's about throwing good money out the window for no reason.
