AC at start up - no cold air? - Page 13 - Dodge Cummins Diesel Forum
post #145 of 999 (permalink) Old 08-07-2012, 11:10 PM
smcguirt's Avatar
Taking my 2012 3500 dually in tomorrow. I am having the same issues. Noticed over the weekend with temps around 100 and I let the truck idle with AC on max, AC did not cool down till moving. I did check the fan today and after initial startup the fan freewheels and AC compressor cycles. I do not have remote start.
smcguirt is offline
post #146 of 999 (permalink) Old 08-08-2012, 12:21 AM
My 2010 doesn't seem to have the same problem but you guys are on the right track and Chrysler does have to fix this.
In the mean time have any of you put an electric fan up front pushing over the condenser? It may take Chrysler a while to come up with a fix.
If you do, make sure you use a Spal fan. If there is a better built fan I am not aware of it. They don't give them away though!
SPAL Automotive USA
2010 3500 DRW Crew Cab, 4x4, 6RFE, 3.73, Big Horn, Turnover Ball.
spuch is offline
post #147 of 999 (permalink) Old 08-08-2012, 01:46 AM
PUREVIL's Avatar
Originally Posted by diesellady View Post
Found it. Right in the beginning of the testing procedure it says if it makes a grinding noise, replace it.
ELECTRONICALLY CONTROLLED VISCOUS DRIVE – 5.9L DIESEL
If the fan assembly does not free-wheel and a metallic
grinding sound exists, replace the electronically controlled
fan drive (Refer to 7 - COOLING/ENGINE/RADIATOR
FAN - REMOVAL).
NOTE: The following test may take up to 15 minutes
to perform temperature.
1. Set the parking brake and verify the transmission
is in park or neutral.
2. Set air conditioner (if equipped) and blower fan to
OFF.
3. Start and allow engine to reach normal operating
temperatures.
4. Stop engine, connect the scan tool and select
appropriate model year and engine option.
5. Check for and correct existing DTC’s
6. Using Tool 6801, backprobe pin 1 of the electronically controlled viscous fan drive connector, with the harness connected located at the lower fan shroud to battery ground.
NOTE: The fan drive control coil is energized to 12 volts at this time.
WARNING: A spark may occur when connecting pin to ground. Be sure that no combustible material is in the area.
7. Using the scan tool, verify that DTC 0480 set. If it is not set, verify that a good ground is available.
8. Start the engine.
9. Actuate engine speed to 2000 RPM..
10. Go to the SENSOR screen and observe the fan speed.
11. Run the engine at 2000 RPM until the fan speed increases to 1850 RPM or more for 30 seconds.
That says its for a 5.9L would that make a difference??? Im going to take it in tomorrow to have the tail gate lock installed so I'll see if they can look at the grind noise.
2005 Ram 2500 5.9L QC SB Laramie. More Mods Than The Truck Is Worth!
2007 Ram 2500 5.9L MC SB Laramie. Kelderman Air Ride. (SOLD
2012 Ram 3500 H.O. 6.7L MC SB Laramie. Carli goodies and American Force 22s.
PUREVIL is offline
post #148 of 999 (permalink) Old 08-08-2012, 02:01 AM
damon.kj7e's Avatar
Originally Posted by brownbear View Post
Right. And, the fan clutch DOES spin initially upon startup. Then, within the first minute, it stops pulling air and starts freewheeling. That's when the AC shuts down as the head pressure goes through the roof. That's why I think there is a problem with the fan clutch itself. I think Ram has a bad run of fan clutches.
I believe the same thing. I really believe this is the issue for most of the no cold air at start up complaints.
If the A/C condenser does not get proper air flow, the high pressure side will trip a safety cutoff switch and disengage the compressor clutch. Simple as that. Thats why once you start driving (getting air past the condenser) the compressor will stay engaged and the evaporator will chill allowing cold air to blow.
Again, I had the same problem. Replacing the defective fan clutch fixed my issue. I suspect, as does brownbear, there was a batch of defected fan clutches. The fix is to get more air past the condenser.
2011' 3500 SRW 4x2 68rfe CCSB Laramie Longhorn | H&S XRT Pro + OD Software (custom no TT, +120HP ) | aFe DPF delete | aFe Trans pan | aFe Diff cover | Bilstein HD's | 1" Daystar front lift | Silverstar Ultra Hi, Low & Fog | Cab Air Filter Mod
damon.kj7e is offline
post #149 of 999 (permalink) Old 08-08-2012, 05:16 PM
smcguirt's Avatar
On startup this morning the AC was blowing cold. So I drove over to dealer anyway to ask service department about it and pickup parts for cabin filter install. Service writer looked at me as if I asked for a moon rock when I described the problem of the AC not cooling at startup idle and then cooling down after moving. I said you have not seen this? No not really was his reply. I asked about fan clutches condenser fans etc. Blank stare is all I got. BTW this is not the dealer I bought the truck at, but close to my home. I told him that it would have to sit and cool down, then try to replicate the problem so I would need to drop it off let it sit overnight and then diagnose the next day. Still undecided on taking back to this dealer. Anyone in the Dallas GA area have this AC problem and what dealers have you dealt with?
smcguirt is offline
post #150 of 999 (permalink) Old 08-08-2012, 05:24 PM
I hope we can all get new fan clutches under warranty.
1995 dodge ram 1500 5.2 gasser
2007 dodge ram 2500 5.9 cummins
2011 ram 2500 6.7 cummins.
BigRedRam95 is offline
post #151 of 999 (permalink) Old 08-08-2012, 05:46 PM
When I took mine in, I didn't ask them if they knew about any problem regarding the AC, rather I told them I already knew about it and told them how I wanted it troubleshooted (see earlier post). Basically I didn't even give him the chance to play dumb.
If your SA hasn't heard about it, he is either lying or has been hiding under a rock! My bet is lying.
Good luck.
2011 Laramie 2500 Mega SRW
Desert Ram is offline
post #152 of 999 (permalink) Old 08-08-2012, 05:55 PM
smcguirt's Avatar
Good luck.
Just called dealer that I bought truck from and told SM there was a problem with the fan and the AC is not getting cold until after truck is moving. He also says he hasn't heard of this. He said to bring it in of course. He mentioned there could be a reflash of the ECM needed and found this online not sure if it is related or this is what he was talking about. Anyone had this flash?
Service Bulletin 341564 for Dodge ENGINE AND ENGINE COOLING | AutoMD
smcguirt is offline
post #153 of 999 (permalink) Old 08-08-2012, 06:22 PM
Well the dealers seem like they cant do anything about the problem. Lets all get together and start a class act law suit. I don't think it would be that hard to win. I think ram would sound kinda stupid going into court and telling the judge that they made there a/c system not to work at idle.
Also anyone with the digital a/c controls and a remote start. Does your a/c turn itself on if over ithink its 70F temp when remote started? Why would the a/c turn itself on with remote start if it is not supposed to work at idle??????
post #154 of 999 (permalink) Old 08-08-2012, 07:41 PM
Thats exactly what I told the service manager yesterday at my dealer.. I realise now, he was just doing what he must of been told by his Chrysler rep. I told them it is unacceptable.
I also looked up the remote start part on Mopars website which quiet clearly states
Originally Posted by Mopar
Mopar has a fully integrated, OEM tested remote start system that allows you to start your vehicle from as far away as 800 feet with just the push of a button. Imagine starting and warming your vehicle from your place of work or home on cold winter days, or cooling the same vehicle on hot summer days.
I just can't believe they are telling the dealers to say that's how it is designed. Thats probably the worst excuse they could of come up with.
2011.5 2500HO CCSB Laramie, 4X4, 68RFE, Flame Red
Ricco is offline
post #155 of 999 (permalink) Old 08-09-2012, 10:13 AM
diesellady's Avatar
Any excuse to do a reflash on our engines. They have done some bad things to the earlier 6.7s with their reflashes. I stay far away from their flashes. It has always been good for me.
2007 6.7 4x4 Laramie ATS 68rfe 5star, Copilot, Edge w/CTS, Atomizer, H&S 5" TB,8"Stacks,ATS Diff, 6" lift Caltracs, Dynatracs
diesellady is offline
post #156 of 999 (permalink) Old 08-09-2012, 11:19 AM
damon.kj7e's Avatar
In the case of some 2012's there is a known issue with the shipped code that adversely affects the performance. Something like limits the fueling to 80% of what it should be doing at WOT. So sometimes its a good thing. Of course, any aftermarket programing would take care of that problem as well.
And Hi Neighbor
