2012 Fuel filter change - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 4th Generation 2010 and up 6.7 Liter Cummins > 4th Gen Powertrain
Old 04-10-2012, 07:36 AM   #1 (permalink)
BEER 30
Jdel325's Avatar
So this will be my first fuel filter change. It is my understanding the 12's have the housing attached to the head so all I need to do is order a filter cartridge? Is this correct?
2012 2500 4x4 CCSB, G56 Gorilla Juiced, H&S Mini Maxx, 5" TBE, DPF and EGR/Cooler MIA, SB DD3250, ARP 625s, 6" BDS Long Arm, Carli Springs, 37" Toyo MT's, 17x9 Fuel Throttles (+1), Mag-Hytec rear Diff Cover, Claymore Hitch Cover
USMC SEMPER FI!
Jdel325 is offline   Reply With Quote
Old 04-10-2012, 09:09 AM   #2 (permalink)
Takes 1 1/8" socket to remove cap.
2011 Ram 3500 Outdoorsman Crew Cab 4X4 SRW LB
07INFERNOREDSRT8 is offline   Reply With Quote
Old 04-10-2012, 09:55 AM   #3 (permalink)
yeah, im curious as well, just got a 2012 also
2012 2500 CTD HO, Dual coolers, snow plow/cold weather prep, Line x, PPE 5inch tip, Bak Flip F1, Mopar fender flares, Husky mud flaps, Weather tech mats, Valvoline PBE/Donaldson filter, vision x light bar, Mag Hytec rear diff cover, Thuren overland suspension.
MPD106 is offline   Reply With Quote
Old 04-10-2012, 11:23 AM   #4 (permalink)
BEER 30
Jdel325's Avatar
So all I have to do is drain it first then remove the cap?
USMC SEMPER FI!
Old 04-11-2012, 12:55 AM   #5 (permalink)
ZOP
Decoder Ring Specialist
ZOP's Avatar
Yup. Crack the yellow valve, it goes like half or a quarter turn, should open easy with your hands. Let it drain while you get a wrench on the top. Open it, swap in the new filter, close the valve and cycle the key on 3-4 times letting the fuel pump run and build pressure and purge air. Then fire it. Do not prefill, do not crank on it, you'll put dirt into the fuel system in the first, and tons of air in your fuel injectors and injection pump in the second. If you got most/all the air out she should light right up and barely stumble if at all.
2011.5 6.7L HO 3500 4x4 ST Crew Long 3.73 SRW L/S Rear 68RFE H&S MM w/ Custom Tuning, B&W+Companion, Mag-Hytec Rear Cover
60 Gal RDS Aux Tank/Tool PacBrake air bags AirLift compressor (wouldn't recommend the compressor kit!)
1984 Ford/IH 6.9L F250 4x4 Long 3.54 Dana Rear 4spd Handshaker
2012 Fuzion FZ305 35' Toy Hauler (no, the Ford does not pull this...)
ZOP is offline   Reply With Quote
The Following 2 Users Say Thank You to ZOP For This Useful Post:
diverb (04-23-2013), Jdel325 (04-11-2012)
Old 04-11-2012, 06:51 AM   #6 (permalink)
BEER 30
Jdel325's Avatar
Perfect, thanks!
USMC SEMPER FI!
Old 04-11-2012, 01:45 PM   #7 (permalink)
racer742's Avatar
Remember the fuel will run down your front diff cover if you don't put a hose extension on the drain tube. I did mine in my garage, attached a hose extension and ran it into a 2 gallon gas can. No mess!
'11 2500 Big horn crew cab short bed. 6.7L CTD, 68RFE 3.73, Shibby egr/cooler delete, 4" SS TBE, XRT-PRO, CCV delete, factory fender flares, front matching tint, line-x xtra.
racer742 is offline   Reply With Quote
The Following 2 Users Say Thank You to racer742 For This Useful Post:
Jdel325 (04-12-2012), u-joint (04-19-2012)
Old 04-12-2012, 07:13 AM   #8 (permalink)
BEER 30
Jdel325's Avatar
Besides the 1 1/8" socket to remove the cap and the extension hose any other tools I will need? Trying to make one trip to the store only. Thanks for the info.
USMC SEMPER FI!
Old 04-12-2012, 10:04 AM   #9 (permalink)
racer742's Avatar
That should do it. You'll need to lube the new o-ring with some clean engine oil--doesn't have to be diesel oil. I bought a specific Snap-On fuel filter socket for it, 1 1/8" but it's 3/8" drive. You don't need very much torque to tighten the lid when done. Just good and snug--it's plastic.
Old 04-12-2012, 11:11 AM   #10 (permalink)
BEER 30
Jdel325's Avatar
Perfect, thanks for the help!!
USMC SEMPER FI!
Old 04-19-2012, 01:09 PM   #11 (permalink)
When refering to cyclying the key or "bump" the starter I am not sure how this will work with my 2011. As soon as my key is turned to the start position my truck automatically turns over until it starts. Will this feature just keep turning over my truck until I turn the key to off? then my lift pump wont run?
In my 2001 your could bump the starter to run the lift pump and it would go for 30 sec or something to prime the system.
cosmo1000 is offline   Reply With Quote
Old 04-19-2012, 01:18 PM   #12 (permalink)
ZOP
ZOP's Avatar
Do not turn it to start. Just to ON not start - after a moment you'll hear the pump cycle for on a few seconds and shut off, then turn the key back to OFF, and back to ON again, you'll hear the pump cycle again. Don't turn it to start. It's unnecessarily hard on your starter, and EXTREMELY hard on the CP3 to run air through it, not to mention you might then be stuck with trying to bleed air out of the fuel rail by cracking injector lines.
cosmo1000 (04-19-2012), u-joint (04-19-2012)
