Water pump failure.. - Dodge Cummins Diesel Forum
 5Likes
post #1 of 32 (permalink) Old 03-16-2017, 08:23 PM Thread Starter
I was driving down the highway to go to work this morning and had the low coolant light pop up. Pulled off to see what was going on only to find coolant pouring out of the bottom of the engine. I was able to flip around and get to the dealership. Just wondering if anyone else had had this issue and at what mileage it happened at. At only 48k miles, I was a little shocked that the water pump would fail this early. My 1978 Jeep is still running the original water pump....
pitcher3853 is offline
post #2 of 32 (permalink) Old 03-16-2017, 11:53 PM
Water pump failure is a known issue,there is a multipage thread on the forum,I don't have the link handy.There is also a thread about the differences in WP's over the years.
Did your dealership have WP in stock?
If Brockman is online maybe he will link to his troubles getting a WP.
gsbrockman likes this.
14 2500/68rfe 4X4 CC SWB Tradesman 315/70/18 Toyo MT's
ARE DCU
2500/6 is offline
post #3 of 32 (permalink) Old 03-17-2017, 05:12 AM
very common problem on these. definitely been some issues getting them at part stores too, so i'd recommend another Cummins one
2011 CCLB 3500, G56, 4'' TBE, Sinister EGR delete, EFI Live by Anarchy
kawakx125 is offline
post #4 of 32 (permalink) Old 03-17-2017, 12:58 PM
FWIW:
I'm running the zone's WP because it has a lifetime warranty. I made the executive decision to use one with a lifetime warranty over OEM because of premature failure. I think a water pump should last longer than 67000 miles. Fool me once kinda thing..
I'd imagine the aftermarket pump has a better bearing/seal. I mean, why would they offer a lifetime warranty if they're going to have to replace it 2-3 times, etc.
Best wishes on your dealer visit. If you had a few sockets, breaker bar and some time handy you could easily do this job yourself. But, if your under warranty i'd take the free inconvenience option too.
hitmix300 is offline
post #5 of 32 (permalink) Old 03-17-2017, 01:06 PM
Danderson's Avatar
As many failed water pump accounts on 3rd and 4th gens are out there,a market exists for a company to manufacture a higher grade pump.
'07 2500 SLT,5.9,regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Toyo AT2's. Dynatrac freespins and bj's. Synergy HD steering. Don's Kings. Anarchy EFI. Personally serviced.
Danderson is offline
post #6 of 32 (permalink) Old 03-17-2017, 01:20 PM
dr.porsche's Avatar
Wow, 67k on a water pump seems short lived. Any ideas as to what causes it, bearings, seals, corrosion?
Doc
2011 Ram 2500 CCSB Laramie, Auto, 4WD, Fully Deleted, RaceMe Tuner, Cool Side Pipe, Bilstein Steering Damper,
steering box stabilizer, 4" JAMO Stainless TBE, FTE Stainless 4"x30" Resonator
dr.porsche is offline
post #7 of 32 (permalink) Old 03-17-2017, 01:31 PM
smelonas's Avatar
I have been sort of contemplating the idea of maybe trying to have a couple prototypes made. Full billet units of course.
I have not looked into it very deeply yet though.
SOMEBODY has to make one. Its truly getting out of hand.
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is online now
post #8 of 32 (permalink) Old 03-17-2017, 01:42 PM
Doc
Quick observation on the bench showed the bearing having so much play it allowed the shaft enough run-out to damage the seal. You should checkout the OP his didn't even make it 50k...! messed up!
post #9 of 32 (permalink) Old 03-17-2017, 11:47 PM
This is completely unacceptable. How long has cummins been building engines? They know how to make a quality water pump.
Sent from my SM-G935V using Tapatalk
dmproske is offline
post #10 of 32 (permalink) Old 03-17-2017, 11:48 PM
smelonas's Avatar
Concentric makes the water pumps....
Sent from my SM-N910V using Tapatalk
post #11 of 32 (permalink) Old 03-17-2017, 11:51 PM
And cummins is bolting them onto their engines knowing full well it is a inferior unit.
HeavyTwo likes this.
dmproske is offline
The Following User Says Thank You to dmproske For This Useful Post:
Carnutdallas (03-19-2017)
post #12 of 32 (permalink) Old 03-17-2017, 11:58 PM
smelonas's Avatar
Go out and find a better one then. When you do, I'll buy 2.
