in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
2010-2012 Powertrain
Follow Forum
Create Thread
UPDATE:
Images posted between 02/20/24 and 02/25/24 may not work, re-uploading the image by editing your post should fix this
More info found HERE
March's Cummins of the Month
is now open for entries!
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 284
Go to page
Go
284
Sticky
Why you shouldn’t overextend your drain intervals.
biblebound
Dec 27, 2014
Locked
9
10
11
219
94K
Mar 28, 2023
by
cumminsturbofreak
S
Sticky
2010-2012 6.7L Service Data & Part #s
shanepx2
Oct 24, 2011
8
9
10
196
328K
Mar 26, 2023
by
TrprGrl
Sticky
New Powertrain Posting Rules - PLEASE READ BEFORE STARTING NEW DISCUSSION.
tryNto
Apr 20, 2022
Locked
0
3K
Apr 20, 2022
by
tryNto
Sticky
Tricks, Tips, and Technical Data
Onelongshot
Aug 31, 2010
6
7
8
146
2M
Aug 5, 2020
by
dadstillsurfs
P
Turbocharge bost control slow to response P226C
pgstar
7h ago
0
63
7h ago
by
pgstar
P
Bandclamp for the crossover ERG pipe
pgstar
10h ago
1
81
9h ago
by
rghavana
T
Help, need a driveshaft flange yoke
TravisC3500
12h ago
11h ago
by
TravisC3500
A
Need a new transmission looking for options, Suncoast, Revmax or local builder.....
avdigigeek
Jul 30, 2021
24
10K
1d ago
by
Site-r
Front Axle u-joints
hers td
1d ago
1d ago
by
05cumminsfella
2010 eating alternators
bradleyweets
1d ago
3
146
1d ago
by
lineman1234
I
P0087 after parking truck for 2 months?
ilovediesel67
Dec 27, 2023
2d ago
by
ilovediesel67
C
2012 ram 3500 dually front axle swap
Cummins20123500
3d ago
1
100
3d ago
by
daltana
S
Transmission Chatter
Seth_2010-6.7
Feb 21, 2024
1
165
3d ago
by
cerberusiam
L
DEF Substitute
Lonesailor
Dec 15, 2012
54K
3d ago
by
Keith06lbz
5
EGR cooler
55fast
Feb 28, 2024
4d ago
by
55fast
68RFE Downshift 1st Gear "Tap" when coming to stop
14 Megacab
Dec 2, 2018
109
33K
5d ago
by
BrokeRedneck
C
HIgh EGT's
cmyers_2496
6d ago
6d ago
by
cmyers_2496
C
White Smoke and a bit of a whistle sound
callidus
Jun 25, 2015
30
14K
Mar 10, 2024
by
mach95sillett
2012 6.7 Cummins running hotter than usual
Wyatt6.7
Feb 14, 2024
31
919
Mar 7, 2024
by
Bootylicious
S
'12 6.7L Cummins Sound
SouthHite
Feb 24, 2024
4
529
Mar 5, 2024
by
SouthHite
G
Wait to start light P0381 Wiring question
grampsbutler
Mar 5, 2024
0
120
Mar 5, 2024
by
grampsbutler
L
2012 3500 6.7 Cummins Stumbles / Surges / Misses when warmed up
Lucifer
Feb 29, 2024
6
290
Mar 4, 2024
by
Lucifer
J
Transmission Cooler lines
jjdamron2
Mar 1, 2024
1
147
Mar 1, 2024
by
BFD
Another P0871 post
smykowski
Mar 1, 2024
0
88
Mar 1, 2024
by
smykowski
S
Best oil for 6.7 Cummins
Semper Fi 6.7
Jul 2, 2016
349K
Mar 1, 2024
by
Believer45
W
Fuel pressure relief valve??
wmdoyle93
Dec 8, 2020
3
2K
Feb 28, 2024
by
Codz24
Aisin trans code P0868
tinner12002
Jul 21, 2020
12
4K
Feb 24, 2024
by
gsbrockman
Maintenance Intervals Then and Now
OldsCool
Nov 1, 2023
10
844
Feb 23, 2024
by
s10010001
Wheel Stud Recall
Audiowriter
Feb 21, 2024
6
370
Feb 22, 2024
by
OldsCool
C
6.7 to 5.9 swap
CodyD
Feb 20, 2024
0
115
Feb 20, 2024
by
CodyD
M
Oil leak past coalescer
Mobilewrench
Feb 14, 2024
17
439
Feb 16, 2024
by
StealthDiesel
random fan clutch engagement
CowboyCummins01
Sep 22, 2020
1
721
Feb 15, 2024
by
Sasa Losic
Engine Tick?????? Please Help!!!
dodgediesel
Jan 14, 2015
4
5
6
221
104K
Feb 15, 2024
by
willzo
Coolant Temp Fluctuates from normal (199) down to 185, then Up to 228, then drops back down
6.7L_MegaCab
Dec 1, 2023
18
898
Feb 15, 2024
by
6.7L_MegaCab
C
2012 DODGE 2500 P0102 CHECKED OTHER FOURMS NO HELP
chasedavis2000
Feb 11, 2024
8
287
Feb 14, 2024
by
chasedavis2000
P
P0934 and p0935 on 13 Ram 2500
PUCKEN
Nov 21, 2020
3
3K
Feb 14, 2024
by
Aronf01
W
Occasional Start problems
wdills
Feb 3, 2024
3
164
Feb 8, 2024
by
#40Fan
Running real rough after head gasket and head install
AaronCDiesels
Feb 7, 2024
3
256
Feb 8, 2024
by
Olypopper
W
P0731 trans code?
weblake
Jun 30, 2013
63K
Feb 7, 2024
by
Pat craddock
1
1 of 284
Go to page
Go
284
111.5K
posts
47.9M
views
Discussion on what directly makes the truck move: Engine, Transmission, Driveshaft, Differentials and Axles
Show Less
Join Community
Grow Your Business
Forum Staff
View All
steve05ram360
Super Moderator
9297oldram
Super Moderator
rghavana
Moderator
Top Contributors this Month
View All
Wyatt6.7
L
Lucifer
ssfortune534
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
