Deleting on The Cheap - Page 2 - Dodge Cummins Diesel Forum
 9Likes
post #13 of 592 (permalink) Old 04-11-2013, 01:01 PM Thread Starter
67guzzler's Avatar
Originally Posted by gan View Post
Where can I find his contact info, sorry new to this forum and diesels in general
Here in the forum: Rollin Smoke Diesel - Dodge Cummins Diesel Forum
World wide web: Rollin' Smoke Diesel - Diesel Perfomance Parts
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is online now
The Following 3 Users Say Thank You to 67guzzler For This Useful Post:
BerzRam (05-15-2013), gan (04-11-2013), nosshane (03-18-2015)
post #14 of 592 (permalink) Old 04-11-2013, 01:20 PM Thread Starter
67guzzler's Avatar
Thumbs up Possible solution for 2011 and 2012 owners?
Originally Posted by Jeeperzz View Post
Remove the plate from the butterfly valve in the intake. Leave it plugged in. The actuator still "closes" but there's no plate to cause obstruction.
Are you suggesting this as a possible solution for 2011 and 2012 owners whose engines dereate when they unplug the EGR?
If it works a good "how-to" with pictures is in order.
repo4sale likes this.
post #15 of 592 (permalink) Old 04-11-2013, 01:24 PM
Originally Posted by 67guzzler View Post
Yes -- until you have to put it back to stock for some reason and pay a boatload for the parts -- if you can find them.
The idea here was to take your parts and store them for easy reversion to stock in the even you want to sell or trade. Hence the comment about putting the parts in the garage in the instructions.
Sorry, missed that part in the write up.
Here are the relevant pics from the write up on another forum
Credit for the pics to Compcowboy over at diesel bombers.com
2010 crew cab, long box, dual rear wheels, laramie. Straight 5" TBE, tuned by Tom, 18k receiver hitch.
Jeeperzz is offline
post #16 of 592 (permalink) Old 04-11-2013, 01:58 PM
Edited into above post
Jeeperzz is offline
post #17 of 592 (permalink) Old 04-11-2013, 02:02 PM Thread Starter
67guzzler's Avatar
GREAT! Thanks for posting. Great fotos!
Forgive my ignorance as I have done anything with the EGR other than either disabling via tuner or unplugging: If the butterfly is removed (i.e. OPEN) all the time, won't the EGR flow all the time? Or does the EGR flow based upon cutting off intake airflow?
OR are you saying remove the butterfly AND plug the crossover.... ????
Thanks Jeeperzz!
post #18 of 592 (permalink) Old 04-11-2013, 02:45 PM
Yes, butterfly and plug. Or, there have been some who have taken a gear out of the egr valve to effectively block it. I don't know too much about that.
Jeeperzz is offline
The Following User Says Thank You to Jeeperzz For This Useful Post:
67guzzler (04-11-2013)
post #19 of 592 (permalink) Old 04-11-2013, 03:44 PM
From looking at it I would say the butterfly is normally open and closes to some degree to take more intake flow from the EGR instead of clean fresh air.
I am fairly sure taking the butterfly out will cause a check engine light. When the truck commands the butterfly closed it will be looking for loss of air flow thru the mass air flow sensor not sure if it would cause a deliverability problem or not. I would not be surprised if it did.
Hopefully someone has tried and can give us a definite answer.
2012 ST CCSB 4x4 68RFE Mineral Gray all stock
[/QUOTE]
mattmanstroked is offline
post #20 of 592 (permalink) Old 04-11-2013, 03:55 PM Thread Starter
67guzzler's Avatar
Interesting....
post #21 of 592 (permalink) Old 04-11-2013, 04:24 PM
I don't think you should get a cel or derate from removing the butterfly plate. The MAF sensor is pre-turbo, I would be surprised if it would register the momentary partial closure of that butterfly valve. The air moving past the MAF sensor should be fairly consistent even if the plate is fully closed (I don't think it ever fully closes), since the turbo will just be building pressure in the system.
Jeeperzz is offline
post #22 of 592 (permalink) Old 04-11-2013, 04:52 PM
Regardless of my opinions this is what H&S have to say about it.
[IMG][/IMG]
Notice that the only mention of a CEL is when the egr is unplugged, or when the butterfly valve is unplugged. It seems that if you can leave them both plugged in you won't have any CELs due to the egr system.
Jeeperzz is offline
The Following 4 Users Say Thank You to Jeeperzz For This Useful Post:
67guzzler (04-11-2013), 84Daytona (10-04-2013), BerzRam (05-15-2013), nosshane (07-21-2013)
post #23 of 592 (permalink) Old 04-12-2013, 04:09 PM Thread Starter
67guzzler's Avatar
Jeeperzz -- Would definitely be interesting to try the butterfly removal / plugged crossover technique leaving everything plugged in and seeing what would happen....
post #24 of 592 (permalink) Old 04-12-2013, 05:16 PM
Look forward to your results!
Jeeperzz is offline
gregpenn (05-20-2014)
