Bully Dog Gt tuner? - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 04-07-2013, 12:48 PM Thread Starter
6.7ctd's Avatar
Question Bully Dog Gt tuner?
I have a bully dog on a 2012 cummins, with a S&B air intake with all the emissions still on. What do you guys dislike about the bully dog tuners?
#2002 24v 5.9, fass fdrp, 5inch Flo~Pro Str8 pipe, edge ez, turbo silencer ring out,shift kit, bd diesel steering stabilizer, BHAF#2012 6.7, s&b intake, Sinister egr delete, dpf delete, 5inch w/muffler, H&S/mcc/AD, TV delete, Arp 2000's, CCV breather GDP
6.7ctd is offline
post #2 of 19 (permalink) Old 04-07-2013, 01:02 PM
r44guy's Avatar
The bully dog tuner works just fine but it will not allow you to perform any emission deletes which is what benefits these trucks the most when it comes to extended engine life, better fuel economy, and obviously more power.
12 Ram 2500 MC, 6.7L Cummins, ARP 625's, H&S Int., Ind. Inj. 100 HP Nozzles, Full Comp. SunCoast Auto. 68RFE, Fuel Lab Velocity 200 fuel system, Ind. Inj. 85% +CP3, ATS Aurora 7500+Compound, & MCC by Ryan.
r44guy is offline
post #3 of 19 (permalink) Old 04-07-2013, 01:04 PM Thread Starter
6.7ctd's Avatar
So you couldn't just clear the engine lights after the deletes?
6.7ctd is offline
post #4 of 19 (permalink) Old 04-07-2013, 01:11 PM
r44guy's Avatar
You can clear the diagnostic trouble codes that cause the check engine light but the truck will not run well enough to effectively drive the truck and the check engine light will come on immediately when you start the truck even if you clear the codes every time.
You will need to reprogram the truck with a tuner that deletes the programming for the emissions like the H&S XRT or Mini Maxx or Smarty Jr. and or Sr. and most of these products are still available but they have all been discontinued due to the EPA crack down about 4 months ago.
r44guy is offline
post #5 of 19 (permalink) Old 04-07-2013, 02:09 PM
→ True Blue ←
67guzzler's Avatar
They key is to stop the regen process first, stop the EGR process 2nd, and supress codes 3rd. The codes aren't the big problem. Those can be cleared.
The Bullydog GT doesn't do anything to help you with the DPF or the EGR. So if you remove the DPF and regens start, you'll have a mess on your hands. Lots of smoke and then a probable limp mode after...
2017 2500 6.4L HEMI™ Crew 4x4 Laramie / "
First Impressions on
Build Quality
2013 3500 SRW CTD Crew 4x4 Tradesman G56 /
/ Sold
2010 2500 CTD Megacab 4x4 Laramie /
/ Sold
"Please don't complain about trivial & inane things about your truck."
67guzzler is online now
The Following User Says Thank You to 67guzzler For This Useful Post:
r44guy (04-07-2013)
post #6 of 19 (permalink) Old 04-08-2013, 06:02 AM
Bigpuddie's Avatar
Well...I run a Bullydog GT and have for 30,000 miles with SIMS , fully deleted TBE and no egr cooler and I am fully satisfied. Half the price of H&S and includes transmission tuning free. I have lots of power, guages, and great fuel mileage. I do have a CEL, but no big deal. Very happy!
2011 Ram 3500 Laramie 4x4 SRW 6.7, Bully Dog GT, a few missing parts,4" TBE exhaust,turbo baffle delete, Kelley 315/70/R17 TSR tires/ stock rims, Reese 20K, Firestone 5K airbags,smoked tail and roof lights, Truck lite LED's,2" Daystar Level kit,Fleetguard filters, Mobil 1 Synthetic oil
Bigpuddie is offline
The Following 2 Users Say Thank You to Bigpuddie For This Useful Post:
David Braa (12-12-2015), davidrenk08 (05-23-2013)
post #7 of 19 (permalink) Old 04-08-2013, 07:26 AM
^^ Right there is what I was gonna say and see as a "fix" to the EPA stuff. Get a set of SIMs and you can still do deletes as long as you have a device that will clear those codes.
'12 Ram 3500 SRW CCLB Carli 3" "Dominator", Trussed and Hydo'd front, AFE Intake, Deleted, 4" TBE, 37" Toyo M/Ts on TrailReady 5½ Black/Black wheels, H&S Mini Maxx Race w/ Trans unlock and MCC tuned by Draconian and ISSPRO triple pillars
NoPlugsRequired is offline
post #8 of 19 (permalink) Old 05-28-2013, 02:58 AM
jaycash's Avatar
i have run the bully dog gt as well. runs great, love it.be sure to get the 100ohm sims, unplug egr, good to go.
2010 LARAMIE 4X4,DPF/NOX DEL,TURBINE MUFFLER,BULLY DOG GT, BOOST FOOLER,AMP POWERSTEP, BUSHWACKER FENDERS,20X10 HD WHEELS,bilstien5100, leveling kit,recon headlights. BADD A$$ DIESEL!!!
jaycash is offline
The Following User Says Thank You to jaycash For This Useful Post:
post #9 of 19 (permalink) Old 05-28-2013, 11:37 AM Thread Starter
6.7ctd's Avatar
Where does the 100ohm sims go?
6.7ctd is offline
post #10 of 19 (permalink) Old 05-28-2013, 11:53 AM
jaycash's Avatar
two on the down pipe, other two where you disconnected dpf/nox.
jaycash is offline
post #11 of 19 (permalink) Old 05-28-2013, 12:02 PM
→ True Blue ←
67guzzler's Avatar
Jay's right. There are 4 total temp sensors (two pronged plugs) and 2 O2 sensors (6 pronged plugs). With SIMS you have to move the O2 sensors over to the replacement exhaust in the bung holes and the 100ohm SIMS get plugged into the 4 temp sensors. Unplug the DPF pressure hoses from the pressure sensor (leaving them open to the atmosphere) and then you're done.
Unplugging the EGR is optional but will make the CEL come on AND may de-rate performance in some 2012 trucks.
-Guzzler
Build Quality
/ Sold
/ Sold
post #12 of 19 (permalink) Old 05-28-2013, 12:10 PM
jaycash's Avatar
i better go in there and gut it, even though i have not had any problems with it unplugged{besides CEL light blinding me at night.lol} it'll be nice if it has been derated and i didnt even know.
jaycash is offline
