New s466/83 no good after install!!! - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-23-2013, 03:46 PM Thread Starter
2raptor5rider0's Avatar
did the 2nd gen swap and got my brand new borg warner s466/83 built buy fleece put in few days ago.i had the local shop install it,they had told me at first the turbos front fan (billit) came apart at start up,but they got thier story backwards somehow.come to find out while they were test driving it it happend.they said a few miles down the road they were goin up a hill an thats when it came apart.when i got it i checked for shaft play,i barley wiggled it but it would touch the side walls.im new on turbos but that just dont seem right.could it just have been a faulty one?
2010 6.7,mini maxx,5" tbe,7" dual stacks,s&b cai,deletes,wcc intake horn,120 ii nozzles,ARP 625's,fpe s466/83 with steed speed 2nd gen mani.
2raptor5rider0 is offline
post #2 of 9 (permalink) Old 03-23-2013, 04:09 PM
Thiago12/6.7's Avatar
Most likely they didnt install it correctly and messed it up, if they are changing stories...
2012 Dodge 2500 6.7 Mega Cab 4x4 Laramie
Mini Maxx OD Tune, Isspro Gauges...5TBE...Egr Delete...Sinister TVD...Silencer Ring MIA....Leveled with 5100's...35x12.5x20 Toyo MT's...180T...Extreme Studs ....2012 Dyno run 399whp
4/13/13 454whp/956tq SOLD
Thiago12/6.7 is offline
post #3 of 9 (permalink) Old 03-23-2013, 04:19 PM
rjp
WWW.SuncoastConverters.co
rjp's Avatar
Care to mention the shops name that did the install?
A change in the story is never the truth!!! I would guess they damaged it upon install and the damaged area decided to self destruct once in operation.
rjp is offline
post #4 of 9 (permalink) Old 03-23-2013, 04:28 PM
If the bearings are toast that soon after install they probably forgot to pre lube it. Seen it happen more than twice on larger equipment.
13 3500 Longhorn Mega
coblanchard is offline
post #5 of 9 (permalink) Old 03-23-2013, 04:45 PM
Temple Diesel's Avatar
iTrader Score: 16 reviews
Did they have to remove compressor cover to install?
2015 Suspended by Thuren goods on 38" Toyos
Temple Diesel is offline
post #6 of 9 (permalink) Old 03-23-2013, 04:51 PM
carpenca's Avatar
You can see pictures of the compressor wheel and an explanation here...
2nd gen swap turbo choices = me useless and going nuts
Landon, its unfortunate this has happened. Truth of the matter is you are caught between a lie and an easy scape goat. Its easy to blame the turbo builder when you may hav developed a level of repore with your local shop. However this is a clear case of foreign object debris damage, and is not an issue caused by somthing Fleece Performance did or failed to do.
Yes the kits take time, as mentioned in the other thread, the majority of the lengthy time is caused by turn around rate of the Steed Speed manifold. We have yet to date been able to accumulate enough to just have sitting on the shelf to send out. As I said before the any short fall in communication is my fault, and I apologize for that.
We will let you know Monday what we can do to get this resolved.
Caleb
carpenca is offline
post #7 of 9 (permalink) Old 03-23-2013, 07:55 PM
whitey70ss's Avatar
Wow from the pic there was some serious foreign matter bouncing around in your turbo.
06' 3500 DRW Laramie, EFI by Anarchy, 4" TBE, CAI.
whitey70ss is offline
post #8 of 9 (permalink) Old 03-23-2013, 08:59 PM
Fenn's Avatar
That sucks bud!
06 2500 mega cab, AFE CAI, 5" TBE, 50hp BMS sticks, FASS 150, Thuren 2" coils, overland shocks, 35" General grabbers, ISSPRO EV gauges
SOLD-2011 2500 6.7L
Fenn is offline
post #9 of 9 (permalink) Old 03-23-2013, 10:08 PM
After seeing the pic of the compressor wheel there was obviously something in the intake tubing when the engine was started.
The shop that installed it needs to step up and replace your turbo because of their fu** up.
