exhaust regeneration - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 03-15-2013, 08:27 PM Thread Starter
mrugg's Avatar
I just bought the truck lastnight and today it says it needs to be preformed. I looked in the owners manual and it says run at highway speeds for 45 minutes should take care of it. Could someone explain exactly what this means. Or any tricks to get this done. This is my first diesel pickup and first dodge truck.
mrugg is offline
post #2 of 16 (permalink) Old 03-15-2013, 08:53 PM
A gentle suggestion . . . do a search and/or actually read your owners manual . . .
This topic is beat to death on a regular basis . . .
- Tim
2011 2WD 2500 Crew Cab ST w/8' bed, bone stock and staying that way . . .
tadawson is offline
post #3 of 16 (permalink) Old 03-15-2013, 09:03 PM
krywanczyk's Avatar
The idea is to get the truck hot to help with the regeneration process in the DPF. The best way to do this is run at highway speeds, if you can tow something that will reduce the time needed since the truck runs hotter when towing. Try not to idle more than a few minutes unless necessary and it should reduce the frequency of seeing this message.
2010 2500 ST/Silver/4x4/68RFE/3.73/ Custom Tuned by Draconian Diesel, Transmission Tuning, ARP 2000's, Sinister EGR delete, Nitto Trail Grapplers 285/75/17, Viper Remote, EBC Green Pads, ISSPRO EV2 Gauges, Mag Hytec Transmission pan & a few other things.
krywanczyk is offline
post #4 of 16 (permalink) Old 03-15-2013, 09:19 PM
MGTEXAS's Avatar
Welcome to the forum and welcome to the amazing world of RAM.
An overly zealous EPA has required that the manufacturers place unnecessary and restrictive emissions devices on our newer trucks. a filter placed on your truck needs to be cleaned, a process that involves you getting your truck nice and hot for a while. I have not heard of this needing to be done so early. How many miles are on your truck? If you have virtually no miles and did not sit and idle all day, I would take it back for a diagnosis. Some claim that a regen can be completed by idling for a couple of hours. I have no first hand experience with that as a way to accomplish this. I have a new 2012 and have not had a regen yet but then again, I tow heavy most of the time it is running.
Hope it all works out.
Mike
2012 6.7, 4wd, CC, DRW, Liner, B&W Turnover Ball
SOLD 4 other 5.9 trucks
MGTEXAS is offline
post #5 of 16 (permalink) Old 03-15-2013, 09:36 PM Thread Starter
mrugg's Avatar
When I bought it,it had 6 miles but it had 3 hours so that tells me it idled alot. Thanks for the good info I will try that tomorrow.
mrugg is offline
post #6 of 16 (permalink) Old 03-16-2013, 09:39 AM
Sounds like washington dc rush hour
oaklandopen is offline
post #7 of 16 (permalink) Old 03-16-2013, 10:50 AM
Bocephus III's Avatar
Mike
if you have over 200 miles on the engine, towing or not, the dpf has performed a regen. you may not realize it has done it, but it has. when towing and getting 8-10 mpg, it is very hard to tell when it regens. when not towing, its easy to tell just by looking at the "on the fly MPG". i have not gone over 200 miles without a regen EVER.
2012 2500|Mini Maxx|Double R Tuned|5'' FloPro|D!ck Cepek GunMetal 7's|295/60/20 Toyo AT II|Thuren 2'' springs|TDK bumper|Firestone bags & Wireless Air Command|Bushwacker flares|Duraflaps|Go-Rhino steps|Lorado tonneau cover
Bocephus III is offline
The Following User Says Thank You to Bocephus III For This Useful Post:
MGTEXAS (03-16-2013)
post #8 of 16 (permalink) Old 03-16-2013, 11:20 AM
diesellady's Avatar
When you take it out on the hwy, run it in 5th gear at around 2500 rpm. This will force a regen and it will take much less time. ")
2007 6.7 4x4 Laramie ATS 68rfe 5star, Copilot, Edge w/CTS, Atomizer, H&S 5" TB,8"Stacks,ATS Diff, 6" lift Caltracs, Dynatracs
diesellady is offline
The Following 2 Users Say Thank You to diesellady For This Useful Post:
MGTEXAS (03-16-2013), Muzbomb (03-16-2013)
post #9 of 16 (permalink) Old 03-16-2013, 11:26 AM
Probably from sitting on the lot being started and shut down who knows how many times. You said three hours on it and six miles, thats alot of idle time. Go for a nice drive in the new truck.
2016 Big Horn 3500 SRW Aisin Leveled 295/65/20 Toyo AT
ndnguyd is offline
post #10 of 16 (permalink) Old 03-16-2013, 11:58 AM
Bettercumminthanstrokin's Avatar
Get out and beat the truck like a red headed step child...if it breaks its under warranty...lmao
Bettercumminthanstrokin is offline
post #11 of 16 (permalink) Old 03-16-2013, 12:05 PM
shawns-cummins's Avatar
I always thought that was strange, when I bought mine last November it had 7 miles on it but already had 6 hours??
2001 2500 QCLB Laramie SLT 4X2 |5.9 HO|6 speed Manaual|3.55|stock|
SOLD,2013 2500 Laramie Longhorn CCLB 4X4|6.7L|68rfe|3.42|2" Level|33's|
SOLD,2012 2500 CCSB 4x4|6.7L HO|68rfe|3.73|Fully Deleted|
shawns-cummins is offline
post #12 of 16 (permalink) Old 03-16-2013, 12:34 PM
They say 45min at highway speeds but I've found it takes a lot less than that.
The one active regen I had to do was over in less than 10min, and I didn't even get to the highway! If you have a manual it helps to run it in a lower gear at higher RPM to get the exhaust nice and hot. Same goes for when you're out on the road trying to regen; its better to run a gear down at high RPM than it is to keep the RPM real low. It's not doing much good if you're turning 1200RPM at 55mph.
Also as a general tip, if you get a chance to take the long way home on the backroads now and then do it to help keep the DPF clean. Keep the RPMs high and romp on it a little and that'll work.
2012 Ram 2500 ST 4x4 G56 Manual CCSB | Smarty J67 ME | Flo Pro 4" O/R pipe | Sinister EGR Delete
BlackandChrome is offline
