people getting error 0 on H&S sd cards - Dodge Cummins Diesel Forum
post #1 of 109 (permalink) Old 12-03-2012, 11:33 AM Thread Starter
Timmay81's Avatar
usually when getting error 0 on the tuner about the SD card i have found this to work pretty good to fix the issue
SD card needs to be 2GB and in FAT format to work properly
-plug SD card into computer and open folder and view contents
-Control +A on your keyboard will highlight all files, Control+C will copy
-Make a temp folder on your desktop(right click on it & make new folder)
-Open temp folder and Control+V to paste
-Goto start menu>computer and find the device - MM or XRT
-Right click on SD card and select "Format" and a new box will open
-Make sure it is in the "FAT(defualt) FAT32 will not work
-Click quick format box then click start and it will say its going to erase click ok
-If id does not say "format complete" then unplug card plug back into another -USB port and try again. this time you will have to type in what type of card it is under " volume label" in the format box
-If it says format complete its good to go, if it says it didnt you have bad card
-If good card, open up your temp folder and re copy the files and paste to SD card
Hope that helps
MM Full SD download- http://www.hsperformance.com/updates...mm_full_sd.zip
HD with ATT- http://www.hsperformance.com/updates...39_hdboost.zip
HD no ATT- http://www.hsperformance.com/updates...d010_39_hd.zip
Mild with ATT- http://www.hsperformance.com/updates...mm_d010_39.zip
mild NO att- http://www.hsperformance.com/updates...10_39_mild.zip
xrt pro full-http://www.hsperformance.com/updates/xrt-pro/xp_full_sd.zip
HD with att-http://www.hsperformance.com/updates/xrt-pro/xp_d010_23_hdboost.zip
HD NO att- http://www.hsperformance.com/updates...d010_23_hd.zip
Mild with ATT- http://www.hsperformance.com/updates...xp_d010_23.zip
Mild NO att- http://www.hsperformance.com/updates...10_23_mild.zip
You can download FULL sd and whichever tune you want, copy the tune specific files to the FULL folder and replace files then copy to the formatted SD card
EDIT. some may run into a error saying unable to open file MMD010.BIN or XPD010.BIN etc.... In this case try this out
After your SD card is fully updated:
1-Copy all contents of your SD card to a temp folder on the desktop, i generally name it the same as the tuner
2- Format SD card to FAT(default) and quick format
3- Take these 4 files MMMenu.BIN(mini maxx) or XPmenu.bin(pro) and vehcile specific file(listed below), hsgrfx and 24fimg and copy them to the blank SD card
4- power up tuner with SD card and either update firmware or select the vehicle, let tuner reboot
5- SD card back to computer and copy rest of the files back to the SD card from the temp folder(do not need to replace the 4 files already on card, can skip them)
6- back to tuner good to go!
heres what each file is for
XRT Pro vehicle .bin files
2006-2007 Dodge- XPd006.bin
2007.5-2009 Dodge- XPd007.bin
2010-2012 Dodge- XPd010.bin
2007.5-2010 GM- XPc007.bin
2011-2013 GM- XPc011.bin
2003-2007 Ford- XPf003.bin
2008-2010 Ford- XPf008.bin
2011-2012 Ford- XPf011.bin
Mini Maxx vehicle .bin files
2006-2007 Dodge- MMd006.bin
2007.5-2009 Dodge- MMd007.bin
2010-2012 Dodge- MMd010.bin
2007.5-2010 GM- MMc007.bin
2011-2013 GM- MMc011.bin
2003-2007 Ford- MMf003.bin
2008-2010 Ford- MMf008.bin
2011-2012 Ford- MMf011.bin
hope that helps
2010 CCSB
Tuned & Deleted
Timmay81 is offline
The Following 10 Users Say Thank You to Timmay81 For This Useful Post:
croakersmoker21 (01-08-2013), dirtynorth49 (02-25-2013), lawlor (05-06-2014), Mudman1 (02-25-2013), NC4stroker (05-21-2013), r44guy (04-01-2013), squinch (01-02-2014), TrueBlueSmoker (03-21-2013), Tyler.G (02-05-2013), v10sport (12-04-2012)
post #2 of 109 (permalink) Old 12-04-2012, 03:10 AM
Seth9180's Avatar
Would this be similar for Mac users?
2012 Ram 2500 CCSB 6 speed 4x4 SLT
, 2" front leveling kit, Bushwacker pocket flares, 35x12.50x18 BFG MTon DC rims. All stock for now but plan to delete soon!!
Seth9180 is offline
post #3 of 109 (permalink) Old 12-04-2012, 11:21 AM Thread Starter
Timmay81's Avatar
That im not sure, the copy and paste part probably but im not really familiar with mac
2010 CCSB
Tuned & Deleted
Timmay81 is offline
post #4 of 109 (permalink) Old 12-04-2012, 12:02 PM
Elkhunter1954's Avatar
Thanks Tim It worked! I have been beating my head against the wall until I followed your instructions. I dont get why this works, as all you do is copy your files from the SD card to your computer desktop..format the SD card and copy those file you just put on your desktop back to the SD card. Makes no sense. They are the same files but after this procedure I now have the Mild No ATT loaded on my MM.
I made two SD cards, one is the Mild No ATT tune and the other is the Mild w/ATT tune so I can change the tune if I decide I want to without having to go back to the computer.
Again Thanks
Blue 2012 Laramie 2500 CC SWB 4x4 G56 MM Mild NO ATT, Timing 3, running Street tune and 4"Flo Pro Delete and Downpipe
Elkhunter1954 is offline
post #5 of 109 (permalink) Old 12-04-2012, 12:06 PM Thread Starter
Timmay81's Avatar
yea i have really no idea why it works either, i guess just the format refreshing it lets them copy over correctly or something
2010 CCSB
Tuned & Deleted
Timmay81 is offline
post #6 of 109 (permalink) Old 12-04-2012, 12:17 PM
Free parts distributor
LaMoparPower's Avatar
i just deleted everything in mine (sd card) and opened the updater and did a full sd card load, also another option..
2013 MCSB, leveled, 20" Hostiles, 295/65 TG, Carli, DTProFab, Thuren, Edge
Originally Posted by jmd025 View Post
Duke, can we get "official G2G backer - outer" put under his name?
LaMoparPower is offline
post #7 of 109 (permalink) Old 12-04-2012, 12:24 PM Thread Starter
Timmay81's Avatar
i've found that to work sometimes but not always
2010 CCSB
Tuned & Deleted
Timmay81 is offline
post #8 of 109 (permalink) Old 12-04-2012, 12:40 PM
I did that and it worked for the Mild with ATT tune, but when I added the Mild No ATT which replaces files with new ones for the No ATT it didn't work until I did what Tim suggests here. It really makes no sense as I used new SD card reformatted, downloaded from H & S, still got the error 0 message until I just put the files on my desktop, again reformatted and recopies those files back to the SD card...and it worked...without having to call H & S.
post #9 of 109 (permalink) Old 12-04-2012, 12:45 PM
Def. good information.. i only had it once and tried one way, good to know!
post #10 of 109 (permalink) Old 12-05-2012, 10:57 AM Thread Starter
Timmay81's Avatar
another thing ive found is if downloading manual files from the website, use google crome or mozilla firefox browsers, internet explorer sucks
2010 CCSB
Tuned & Deleted
Timmay81 is offline
post #11 of 109 (permalink) Old 12-06-2012, 07:40 PM
do you remove the full sd and then install just the tune wo /ATT, I have tried both ways and I can up date the filmware with the full sd, but not the one with out ATT?
hmtrunner is offline
post #12 of 109 (permalink) Old 12-06-2012, 07:50 PM
No, download the tune NO ATT, copy the files onto the SD card that has the full sd tune. It will ask if you want to replace files with new ones...yes, you want to copy the new and replace the ones that are already on the card. Then you put card in tuner, and update the firmware...if you get an Error 0 message from the tuner then try doing what Tim suggests at the start of this thread. It worked for me
The Following 2 Users Say Thank You to Elkhunter1954 For This Useful Post:
freytes2004 (02-18-2016), Mudman1 (02-25-2013)
