people getting error 0 on H&S sd cards - Page 2 - Dodge Cummins Diesel Forum
post #13 of 109 (permalink) Old 12-06-2012, 06:53 PM Thread Starter
Timmay81's Avatar
no need to have full SD then if you wanna change to different tune just copy and replace those files
2010 CCSB
Tuned & Deleted
Timmay81 is offline
post #14 of 109 (permalink) Old 12-07-2012, 12:12 AM
Done all that, twice, and still having a issue, this is with a new sd card.
!!!!! Got it working!!!!!!!Hell yes.
2010 2500 CC SWB 4x4 3.73 5" TBE, DD Tune.
TexanPower is offline
post #15 of 109 (permalink) Old 12-07-2012, 01:23 AM
What did you do to get it working? I've tried them all.....twice
Thanks to Tim for posting up. It didn't work for me, but I learned alot of things about my computer
I'm off to try LaMoparPower's way. The snow is getting deep quick, and the Mild ATT tune is not going to be fun in the AM.....plus it seems to have alot of glitches in it( Throttle surge just off idle and cutting out when I step on it)
2011 3500 ST DRW CREW 4x4 with a g56....my new beater.
plumber mike is offline
post #16 of 109 (permalink) Old 12-07-2012, 10:09 AM Thread Starter
Timmay81's Avatar
I would suggest downloading the Full SD manual update to the computer from H&S, then you have a fresh update to start with
MM- http://www.hsperformance.com/updates...mm_full_sd.zip
XRT- http://www.hsperformance.com/updates...xp_full_sd.zip
2010 CCSB
Tuned & Deleted
Timmay81 is offline
The Following User Says Thank You to Timmay81 For This Useful Post:
plumber mike (12-07-2012)
post #17 of 109 (permalink) Old 12-07-2012, 11:23 AM
Talked to H&S Tech.....
......off to find a 2GB SD Card.
What a PITA. I miss my CEL and SIMS.
post #18 of 109 (permalink) Old 12-07-2012, 01:14 PM
Well it seems 2GB SD cards are not readily available in the real world.
I am impressed with H&S Tech support. They are sending me a new card formatted and loaded with the Mild No ATT for me
You Tech-e types could probably make a few bucks off us non tech guys selling SD cards pre-loaded with tunes. I know once I get my truck running right again, I AM NOT FING WITH THIS AGAIN!!!!!
post #19 of 109 (permalink) Old 12-07-2012, 02:33 PM
bsherrin01's Avatar
I want to download the no att tune also. If I do and for some reason it does not work will my truck be dead in the water or will it still have the tune that was previously installed on it and be good to drive?
Sent from my iPhone using AutoGuide.com Free App
2012 CC SWB 4X4 w/manual trans, H&S XRT Pro, 4" TBE w/6x18" MBRP Tip, Full Deletes & much more to come
bsherrin01 is offline
post #20 of 109 (permalink) Old 12-07-2012, 02:48 PM
Yeah. It's still got the tune that came with it......which loaded up fine with the same SD card two weeks ago
post #21 of 109 (permalink) Old 12-07-2012, 02:53 PM
bsherrin01's Avatar
I also wasn't planning on buying another sd card and was going to download the no att tune on the original sd card that came in my XRT
post #22 of 109 (permalink) Old 12-07-2012, 02:57 PM
Niether was I
post #23 of 109 (permalink) Old 12-07-2012, 04:49 PM
Just to throw another wrinkle into the mix. H and S tech fixed my 2nd card I bought myself so that it would update the firmware successfully. I went to load the tune on the truck (first time ever) and after getting through the disclaimers, the MM locked up and said it could not find d010 file. Had to unplug it to get it to work again. Luckily it did not get far enough to change anything on my truck that I can tell. It did pull in the VIN and changed my pyro1 reading to 4850 or thereabouts. H and S is sending me a new card also but I am already on a new one. Getting very worried about this whole process now. Like maybe corrupting my truck computer and being dead in the water.
About finding the cards, Radio Shack told me to check the pharmacies for that size card and I found them at Walgreens.
2011 Black pearl 3500 crew cab short bed, 373 auto Not stock now. MM, Foldacover tonneau. 305-70/17 Terra grapplers.
Drgnrdr is offline
The Following User Says Thank You to Drgnrdr For This Useful Post:
post #24 of 109 (permalink) Old 12-07-2012, 05:01 PM Thread Starter
Timmay81's Avatar
Its not going to corupt the vehicle, only thing its going to do is not be able to download, the MM/XRT needs to pull the files from the car in order to get into a download so if it cant get those then it cant get far enough to even start actually programming
2010 CCSB
Tuned & Deleted
Timmay81 is offline
