Exhaust Regeneration - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 09-28-2010, 08:45 AM Thread Starter
Dug
Dug's Avatar
The manual says the exhaust regeneration information will be provided by the EVIC. I have 7000 miles on my 2010 Cummins and I know it regenerates often but I haven't seen any information on the EVIC. How do I get the information out of the EVIC? Thanks for any information on the subject. Dug.
Dug is offline
post #2 of 21 (permalink) Old 09-28-2010, 08:50 AM
insane3639's Avatar
iTrader Score: 6 reviews
This is where the manual is mis leading you actually won't see anything til you reach 80% capacity and so on. and their is no way to pull info afaik
2007.5 SOLD.
2005 SOLD.
1994 12 VALVE PROJECT
insane3639 is offline
post #3 of 21 (permalink) Old 09-28-2010, 12:58 PM
7492's Avatar
Only if somthing is wrong.
07 Megacab 3500 4x4 6.7Liter 68RFE 22 MPG highway.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #4 of 21 (permalink) Old 09-28-2010, 03:54 PM
BlueBeastCTD4x4's Avatar
Straight from the manual(very misleading):
Electronic Vehicle Information Center (EVIC)
Displays
When the appropriate conditions exist, the EVIC displays
the following messages:
• Service Air Filter
• Perform Service
• Exhaust Filter XX% Full
• Exhaust Filter Full – Power Reduced See Dealer
• Service Required – See Dealer Now
• Exhaust System – Regeneration Required Now
• Exhaust System – Regeneration In Process
• Exhaust System – Regeneration Completed
2015 Ram 2500 6.7l Crew Cab 4x4 Maximum Steel Metallic.
BlueBeastCTD4x4 is offline
post #5 of 21 (permalink) Old 09-28-2010, 05:24 PM
AlphaInfinity's Avatar
Displays
Service Air Filter
Perform Service
Exhaust Filter Full Power Reduced See Dealer
Service Required See Dealer Now
Exhaust System Regeneration Required Now
Exhaust System Regeneration In Process
Exhaust System Regeneration Completed
Yes this is very misleading. I am wondering if they decided at the last moment to disable the regenration in process messages in the EVIC? If so, I would like to know how to enable them.
AlphaInfinity is offline
post #6 of 21 (permalink) Old 09-28-2010, 05:44 PM
08 Black Cummins's Avatar
yeah, I've got 8k on mine and never got a message. The real indicator is when the evic mileage goes from 20mpg to 13mpg.
2015 6.7 Crew Cab Big Horn- Stock
2010 6.7 Mega Cab Laramie 4x4- Slighty Modified
SOLD08 6.7 Auto QC 4x4-Not so stock
08 Black Cummins is offline
post #7 of 21 (permalink) Old 09-28-2010, 06:09 PM
i was thinking the same...
post #8 of 21 (permalink) Old 09-28-2010, 06:18 PM
Thats what everyone says but mine stays pretty much in the same MPG range: high 16s to low 17s on highway at 70-75. mid 14s to low 15s in the city.
I never see such a big drop, such as 20-13 or so.
And the "milage coach" jumps around way to much, it never stays constant even at a steady speed on flat highway.
Hope that all makes sence.
post #9 of 21 (permalink) Old 09-28-2010, 10:38 PM
Tech support junkie
powerstroke8994's Avatar
Ya know pickups are alot different than medium and heavy trucks. Unless its just using its own exh heat it will always display when the filter needs a regen. You can start a parked regen or or drive it. Sometimes you must do a parked regen on a truck too. 7492 will agree on this too. You may only see this message a few times depending on how you drive the truck and a bunch other things. They are making these new trucks try and do all the regening without us having to make a big deal about it. Only way to know is as a few said look at your mileage or install a pyro gauge
2014_F-250_Platinum
SOLD-2010_48re
SOLD_2013 MEGA_g56_laramie_Loaded
CUMMINS & N SERIES
Powering Americas Future
powerstroke8994 is offline
post #10 of 21 (permalink) Old 09-28-2010, 11:01 PM
how long does it take befor the fillter is full and is it something that can be cleaned out on your own or are you at the mercy of the dealer
mattyl is offline
post #11 of 21 (permalink) Old 09-28-2010, 11:22 PM
Tech support junkie
Your filter needs to be cleaned every 100,000 or 3000hr(i think the hr is correct) You can take it to your local cummins dealer to have it cleaned or take it to chrysler. No you can not clean it yourself. The filter has to be heated for XXXX amount of time then its blow out or shaken out. Im not too sure excatly how the cleaner does it thing cause we dont have one. Our dealers cheap and wont spend the 50,000 they cost.lol I know ATOUCH on here works for cummins and we send our crap out to so i bet he can tell you
2014_F-250_Platinum
SOLD-2010_48re
CUMMINS & N SERIES
post #12 of 21 (permalink) Old 09-29-2010, 06:02 AM
7492's Avatar
Are you sure about cleaning the Dodge version ? Remember the truck ones we see can be taken apart to cleaned. Look at the Dodge AKA Blue Tec, and I'm not so sure. Did you read the 100 K 3000hr?
7492 is offline
