2012 best way to 500 rwhp - Dodge Cummins Diesel Forum
 10Likes
post #1 of 46 (permalink) Old 05-13-2017, 12:28 PM Thread Starter
Hello all you gurus. I have been a member on this forum for some time but haven't made a lot of posts. I have 3 trucks all purchased from the classifieds here. I have a 1991.5 Intercooled W250 as my beater truck, with a fuel pin, timing bump, Bosch injectors, upgraded turbo, pushing close to 300HP I guess. I then have a 2006 Mega 2500 with Stainless twin turbo 5 wheels, twin cp3's, 60% over injectors, Banks intercooler, big intake with heater delete, ported head, which pushes about 800HP to a Garmon stage 4 trans. This truck is my toy.
My last truck is a 2012 2500 limited that is deleted with a Raceme programmer running the performance tune. Well, it just blew the head gasket, so I am putting it back together with ARP 625 head studs. The Raceme tune is not enough for me, so I would like to get this thing up to at least 500 RWHP. From my research I will need to upgrade the trans, which I plan on sending to Garmon for a stage 2 upgrade. It seems that I will need to add a lift pump. Also, it seems that I will need more boost. I would like to go to twin turbos, using the stock turbo if possible and adding a second one, probably a 475. I also am planning on going to EFI live. Here are my questions:
1. Is this the best turbo setup? I would prefer to keep the turbine brake, and then I would only need to buy one new turbo. I do have an extra 2nd gen manifold if I need to change manifolds. I don't need the turbine brake, so tell me if this doesn't make sense. I want to keep the EGT's down, and from what I have read 500HP with only the stock turbo is going to get hot, if I can even get it there.
2. Will the stock fuel pump keep up, if it has a lift pump?
3. I am pretty sure I can reach my goal with stock injectors, but tell me if they need to be over sized.
4. Should I put a Banks intercooler on it? Also, do I need an aftermarket intake? I do want to retain the grid heater.
5. Anything else I am missing?
Thanks in advance for any help you can provide.
Ambull is offline
post #2 of 46 (permalink) Old 05-14-2017, 12:22 AM
01calicummins's Avatar
pretty sure anarchy made north of 500hp on a stock truck, believe it was 528 or something around that number. Are you looking for a usable to 500hp or a "my truck dyno'd at 500hp" because those are two very different goals.
Tons of guys running the stock intercooler well past the 500 mark so id spend that money elsewhere, same with the injectors, again this is just from memory but i believe stock fuel is good to north of 600hp, the 6.7s love air compared to the 5.9s.
the sxe364 is going to get you to your number or any wheel bigger than that, fleece and BD both make modified VGT turbos that are rated to make 600+ so thats an option you can look at as well.
Twins are defintley cool though and i hear the egt difference is pretty awesome, will be the route i go when i finally decided to throw more at the truck
Ambull likes this.
2014 CCSB 4x4 Leveled, 37x12.5x20 cooper STT PRO, RaceMe Ultra w/ Warp by DoubleRDiesel, 5in flo pro, dynod 433/912 on 120 12v tune
1998.5 CCLB Built 550rwhp, 6ins on 37s and 20x12s SOLD
01calicummins is offline
The Following User Says Thank You to 01calicummins For This Useful Post:
Ambull (05-14-2017)
post #3 of 46 (permalink) Old 05-14-2017, 12:35 AM
World Champs!!!
MoparProud's Avatar
Get a tune and call it a day. Very usable.
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
The Following User Says Thank You to MoparProud For This Useful Post:
Ambull (05-14-2017)
post #4 of 46 (permalink) Old 05-14-2017, 07:50 AM Thread Starter
I definitely want usable HP, not just 500 on a dyno. Thanks for your replies. I will most likely look at twins, I think it is probably the same as going to a big VGT dollar wise. I know from my 2006 that a good turbo setup really helps things, as the truck gets 800 HP and the EGT's don't go over 1300.
Ambull is offline
The Following User Says Thank You to Ambull For This Useful Post:
Ash2012 (05-26-2017)
post #5 of 46 (permalink) Old 05-14-2017, 08:10 AM
BobSagetIsGod?'s Avatar
Tuners are getting nearly 600 horsepower out of a tune on an otherwise stock truck.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #6 of 46 (permalink) Old 05-14-2017, 08:19 AM
Anarchy Diesel
3brorce's Avatar
iTrader Score: 8 reviews
Not on 10-12s.
708-990-7006
Anarchy Diesel Tuning
EFI Live BETA Tester
Custom tuning with EFI Live/H&S MCC/HP Tuners/WARP/EZ Lynk
3brorce is offline
post #7 of 46 (permalink) Old 05-14-2017, 08:32 AM
Originally Posted by 3brorce View Post
Not on 10-12s.
What are you squeezing out of them?
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #8 of 46 (permalink) Old 05-14-2017, 08:56 AM
Anarchy Diesel
3brorce's Avatar
10-12s are the bastard child. Lucky to get 500-525hp it seems. 13-17s realistically make 540-550 on a good day. Perfect conditions you can squeeze out a little more.
Mopar71 and dixon700 like this.
708-990-7006
3brorce is offline
post #9 of 46 (permalink) Old 05-14-2017, 12:09 PM
Mopar71's Avatar
Phil why do the 13+ trucks make more HP etc?
Grey 2010 2500 CC SB 4x4 6.7 68RFE
XRT PRO ATD/ MCC /Trans tuning/WD ARSON III CP3/A1 Head studs/EGR cooler Delete/ Flow Pro 5 inch exhaust/ Edge Insight CTS2 EAS EGT/3.73 gears
Gear brand 17x9 wheels/Nitto Teara Grapler 35x12.5x17 tires
SGT miller proudly served 12 years in the US Army reserves Support our troops
Mopar71 is offline
post #10 of 46 (permalink) Old 05-14-2017, 03:06 PM
dixon700's Avatar
This is what I was thinking. It shouldn't be hard to get 500hp.
04.5qcsb 3/4hd built 47re kilduff isspro adii motorsport diesel 100%over 10.6cp3 bypass CPP stainless diesel63 over s475 trac bars mishimoto Hamilton pusher arp smarty touch udc basic 4"-7"stacks 4.10's 6"lift 37"toyo mts eagle dynatrac
dixon700 is offline
post #11 of 46 (permalink) Old 05-15-2017, 10:55 PM Thread Starter
Well I am adding an S480 turbo to my stock one, adding a lift pump, and adding a Garmon Stage 2 trans. I will keep you posted as to how it works out. Should take about a month to put it all together.
Ambull is offline
post #12 of 46 (permalink) Old 05-16-2017, 05:02 AM
No need for the lift pump if you're staying stock injector/stock cp3. I'd run an 75/96/1.32 over stock versus an s480 as well.
'10AIRSOLD
'14AIR-FUELSOLD
'17
The Following User Says Thank You to BobSagetIsGod? For This Useful Post:
Ambull (05-16-2017)
