Help with MM3 - Dodge Cummins Diesel Forum
 4Likes
  • 1 Post By phale
  • 1 Post By matt1505
  • 1 Post By Jeffro2912
  • 1 Post By firervfd37
post #1 of 12 (permalink) Old 02-15-2017, 01:24 PM Thread Starter
matt1505's Avatar
Help with MM3
I've successfully loaded my tunes from Anarchy and removed the exhaust, unplugged the 4 appropriate connectors under the hood and yet I'm still getting codes on the EVIC to service DEF system and service exhaust system. I plan to put in a call or two when I get home but for now does anyone have any input to what I may have overlooked or done wrong?
2013 2500 tradesman, 68rfe 4x4, Lemon
2016 2500 Tradesman G56 CURRENT
1969 International Scout 800A 196 C.I. 4cyl
matt1505 is offline
post #2 of 12 (permalink) Old 02-15-2017, 02:14 PM
BobSagetIsGod?'s Avatar
Prolly just something that needs to be modified in the tuning.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #3 of 12 (permalink) Old 02-15-2017, 02:16 PM
Anarchy Diesel
3brorce's Avatar
iTrader Score: 8 reviews
What codes are you getting? Are you sure you have the tune loaded?
708-990-7006
Anarchy Diesel Tuning
EFI Live BETA Tester
Custom tuning with EFI Live/H&S MCC/HP Tuners/WARP/EZ Lynk
3brorce is offline
post #4 of 12 (permalink) Old 02-15-2017, 02:21 PM
Anarchy Diesel
phale's Avatar
OP, check your email. You have an email with updated tune files.
overactor likes this.
Cody Hale
423-815-5582
EFI Live Cummins Beta Tester
phale is online now
post #5 of 12 (permalink) Old 02-15-2017, 02:23 PM
overactor's Avatar
He must have ran into the same issue that I had. Thanks for the emails back. Damn firmware updates
2.2BAR in my 4cyl street car
overactor is offline
post #6 of 12 (permalink) Old 02-15-2017, 03:33 PM Thread Starter
matt1505's Avatar
Updated files took care of it!! Patrick, you and you team at Anarchy Diesel have provided me with outstanding support and service, I really do appreciate it. As for the tunes, my truck finally runs, smells and sound like a cummins should!! And the tuning doesn't allow it to fall on its face between shifts like the stock tuning did
3brorce likes this.
matt1505 is offline
The Following User Says Thank You to matt1505 For This Useful Post:
3brorce (02-15-2017)
post #7 of 12 (permalink) Old 02-15-2017, 03:55 PM
firervfd37's Avatar
Mine came in the mail today, just to be received by a thrilled wife to see a tuner, race pipes and egr race kit. Hopefully i dont run into the same issues. OP if you dont mind me asking how did you run the cable through the firewall? Can you run it from the engine compartment in, so that you only need to run the wire through instead of the plug? Thanks from a newbie
2015 2500 Cummins, completely stock as of now...Infantry Leads the Way...
firervfd37 is offline
post #8 of 12 (permalink) Old 02-15-2017, 03:58 PM
Jeffro2912's Avatar
The guys over at Anarchy are outstanding! Extremely quick response time and plenty knowledgeable.
3brorce likes this.
Jeffro2912 is offline
The Following User Says Thank You to Jeffro2912 For This Useful Post:
post #9 of 12 (permalink) Old 02-15-2017, 04:14 PM Thread Starter
matt1505's Avatar
There was an unused grommet on the fire wall under my clutch master cylinder that I stabbed a whole thru and routes the cable into the cab
matt1505 is offline
post #10 of 12 (permalink) Old 02-18-2017, 01:43 PM
firervfd37's Avatar
Finally installed the MM3 and got stock tune emailed to MM3tuner. I can drive the truck for now since she's stock still and not install the tunes once I get them. Hopefully add the race pipes and egr delete next weekend. Also this is where I installed the boxes under the dash area.
3brorce likes this.
post #11 of 12 (permalink) Old 02-18-2017, 02:47 PM
firervfd37's Avatar
My MM3 is staying on after truck is off?
post #12 of 12 (permalink) Old 02-18-2017, 02:49 PM
firervfd37's Avatar
10-22 it turned off
