Best location for Flo Pro twister - Dodge Cummins Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 01-31-2017, 07:07 PM Thread Starter
So, just got my Flo pro race pipes in today with a 4" Flo Pro Twister. The MM3 will be in tomorrow. Question is, where is the best location to place the Twister ? I was planning on putting it in the first delete pipe about 4" past the bolt on flange to the downpipe. I read that a resonator works the best as close to the downpipe as possible.. anyone have experience putting one there or other locations? Thx
2016 Ram 2500 Laramie Sport Pearl White.. Stock for now
Megaramasaur is offline
post #2 of 13 (permalink) Old 01-31-2017, 07:42 PM
Put it as close to the downpipe as you can in your delete pipes. Wherever you can make it fit
2015 2500 Laramie ccsb CTD, Lots of thuren goodies, fox shox, bmf novakanes, amp steps, lost a few parts underneath, and the list goes on......
Mmecsics is offline
post #3 of 13 (permalink) Old 01-31-2017, 07:49 PM Thread Starter
Thanks, That's what I thought.. it will fit easily right after the bolt on flange to the down pipe.
post #4 of 13 (permalink) Old 02-02-2017, 10:16 PM Thread Starter
Man, deleted today and put the Twister in 3" from flange.. it sounds really good, no drone and has a good tone
post #5 of 13 (permalink) Old 02-03-2017, 12:30 PM
rainman428's Avatar
I absolutely love these things. I put one in our self propelled sprayer, and the noise difference is unbelievable
rainman428 is offline
post #6 of 13 (permalink) Old 02-03-2017, 12:34 PM Thread Starter
Yah, good investment in my opinion.. can't hear any drone at any speed
post #7 of 13 (permalink) Old 02-07-2017, 07:08 PM
aneufeld's Avatar
Hey I've got a question for you about the whole race pipe thing that you got from Flo Pro. I was interested in this pipe setup but it says that it has no bungs. Now, I am new to the diesel scene as an owner so I don't really know EXACTLY what a guy needs and doesn't.
My understanding is that you don't need bungs because the programmer will override the sensors? Is this true or did you have to tap bungs in? How did you like your twister and did you use a twister and resonator or are they the same(flopro site calls it a muffler 😐 )?
Sent from my Pixel using Tapatalk
2011 Ram 3500 LB
Stock Engine and Trans
Lifted--35x12.5 on 17
aneufeld is offline
post #8 of 13 (permalink) Old 02-07-2017, 09:40 PM Thread Starter
You don't need bungs, the programmer disables all the sensors. I love the Twister, I just used the Twister only no other muffler or resonator, this is both in one.. I have a short video/sound clip but I can't load it here for some reason.. PM me your phone number and I'll text it to you
The Following User Says Thank You to Megaramasaur For This Useful Post:
aneufeld (02-07-2017)
post #9 of 13 (permalink) Old 02-07-2017, 10:10 PM
acnu34's Avatar
I just did the flopro 4" on Saturday and I did it with no bungs because the tuner deleted the sensors and I couldn't get them out. (NE RUST). I used dielectric grease to fill the sensors and heat shrunk them shut! A little electrical tape for good measure. A few zip ties and we were in business. I was going to get the twister but find I don't need it. I have no drone (yet). Only about 100 miles on the pipe. Towing south on the 18th. I'll keep posted how the trip went. Flopro stated 50lbs of torque on the band clamps. So that's what I did!! Good luck. I love the delete!!!
acnu34 is offline
The Following User Says Thank You to acnu34 For This Useful Post:
post #10 of 13 (permalink) Old 02-12-2017, 02:17 PM
wdimig's Avatar
Here's what mine sounds like 5" SS with the 17" SS twister resonator installed right behind the down pipe, I love the way it sounds, not straight pipe loud, but can def. tell something is done to her!
https://youtu.be/eTPw9r09I7k
Friendofcoal76 likes this.
2010 2500 Deep Water Pearl Blue/tan two tone Mega cab 6.7L Laramie, ARP 625's, GDP Air Boss/ Blue S2 Intk. man./ billet Mega Grid heater/ Pro wastegate, FASS 150 w. Beans sump, EFI Live W. CSP5 switch from Anarchy Diesel, Sinister EGR delete, S&B intake w. scoop, Flo-PRO 5"SS TBE w. 17"SS res., Turbo Lab of America 67mm billet HE351VE w. 67mm 10 blade turbine, Revmax VB & Billet TC filter spud, DTT billet aluminum blue CCV cover, Isspro FM Exh. Pres. & Fuel Pres. gauges, DSOT 5" Drv. Shaft w. 1480 U-Joints, Nitto 285/70/17 EXO Grapplers, Retrosolutions 55W 4300k HID's Lows, Fog's & Hi's Dyno #'s 496/1080 on MASS. Diesel's 224XLC Dynojet
wdimig is offline
post #11 of 13 (permalink) Old 02-19-2017, 07:47 PM
Riddler6.7's Avatar
I am planning on doing the delete pipe and am trying to decide if I need to run a resonator or something too. When I had my 07.5 and deleted it. The drone was unbearable when pulling my toy hauler. I ended up throwing a 30" FTE resonator on it. Solved every bit of drone I had...
I wonder if I better just do it to be safe. Can anyone compare the twister to the FTE or aeroturbine?
Sent from my SM-T567V using Tapatalk
2014 Laramie 3500 CC/DRW 4x4
Aisin, 4.10s, Dark Cherry Red
Riddler6.7 is offline
post #12 of 13 (permalink) Old 02-19-2017, 08:05 PM
firervfd37's Avatar
I'll let you know hopefully soon abiut drone also, installed MM3 yesterday, emailed stock tune and just waiting on the tunes to be emailed back. I believe I can't change the pipes and egr delete until I get the tunes in hand correct? MM3 was fairly simple to install also. Anyone have a video of there truck with the 4 inch race pipes added? Hoping to hear what I'll be expecting.
firervfd37 is offline
