CCV delete kit issues - Dodge Cummins Diesel Forum
 2Likes
post #1 of 16 (permalink) Old 01-17-2017, 04:16 AM Thread Starter
I just installed the Glacier Diesel CCV delete kit on my 2013 6.7. Now about every 50 miles I get the p04db code. I know this is for "Crankcase vent disconnected" Is that typical for a CCV delete kit? and is it okay to keep running it and just keep erasing the DTC? Thanks!
RVR2SND is offline
post #2 of 16 (permalink) Old 01-17-2017, 04:26 AM
Ratdog1's Avatar
Is your rig tuned ?
Sent from my SAMSUNG-SM-T217A using Tapatalk
2016 4x4 3500 Laramie CCLB LOST MY EXHAUST SO I HAVE AN 18 INCH RESONATOR AND EGRDELETE.. ALSO HAVE EFILIVE BY PPEI
3.42 rear ,68 trans TUNED BY PPEI
Ratdog1 is online now
post #3 of 16 (permalink) Old 01-17-2017, 07:17 AM Thread Starter
Yes, Efi live, and all the deletes
RVR2SND is offline
post #4 of 16 (permalink) Old 01-17-2017, 07:30 AM
N1NJ4ON3R's Avatar
Your crankcase filter need to be replaced or the media removed. It is seeing restriction.
-2008 6.7l QCLB 4x4,g56,J-67(23ME),valair DD,64.5/72/14,2nd gen mani,arp 425's,boost and pyro... -1993 W250 CCLB...
-1996 brewed s14 w/ 386 rwhp & 341 rwtq @19psi twinscroll baby!!!(gt3076r)
N1NJ4ON3R is offline
post #5 of 16 (permalink) Old 01-17-2017, 07:50 AM Thread Starter
Okay, so I need to remove the media then. the crankcase filter is new maybe two months old, and I have the little breather sticking out there on the side of it.
I guess having it connected to the intake helps suck the vapors up thru the crankcase filter. Without that the gases are just floating in there barely escaping thru the breather.
But thanks!!
RVR2SND is offline
post #6 of 16 (permalink) Old 01-17-2017, 09:02 AM
krs
krs's Avatar
That breather will get oily and drip a gross mess all over your exhaust manifold. Throw that thing in the garbage and run a hose to your axle. I have tried those GDP kits a couple times. Mistake. Yes you have to remove the media inside because you have a restriction on the engine now. When it was still plumbed into the intake upstream of the turbo the turbo would help pull the gases through the ccv filter.
krs is offline
post #7 of 16 (permalink) Old 01-17-2017, 09:24 AM
Anarchy Diesel
3brorce's Avatar
iTrader Score: 8 reviews
You need to have your tuner shut off the P04DB.
708-990-7006
Anarchy Diesel Tuning
EFI Live BETA Tester
Custom tuning with EFI Live/H&S MCC/HP Tuners/WARP/EZ Lynk
3brorce is offline
The Following User Says Thank You to 3brorce For This Useful Post:
N1NJ4ON3R (01-17-2017)
post #8 of 16 (permalink) Old 01-17-2017, 09:32 AM
Ratdog1's Avatar
Like he said ....
post #9 of 16 (permalink) Old 01-17-2017, 12:28 PM
iTrader Score: -1 reviews
As stated above, run a hose to the ground.
2012-Ram Outdoorsman-2500-RCLB-4X4-HO-auto-3.73 LS-Silver Monotone-Dual trans coolers-Nav with backup camera-cab lights-adj pedals-upgraded alum wheels-heater cord-285-70x17 tires-Ranch Hand grille guard and custom made cb bracket
hemiplymouth is offline
post #10 of 16 (permalink) Old 01-20-2017, 11:57 PM
Deleted16's Avatar
I Have the GDP CCV kit ready to be installed on my '16. Haven't yet as I changed my mind to run a hose down instead. In the case this happens to me as well does anyone mind explaining what this 'media' is that may have to be removed?
If she don't blow black Taker back
Deleted16 is offline
post #11 of 16 (permalink) Old 01-21-2017, 12:13 AM
Shock88's Avatar
the media they r talking about is just the actual filter material, u just need to rip it all out and put the empty plastic shell of the filter back in. it has much less restriction then leaving the filter material in and cause a CEL
Shock88 is offline
post #12 of 16 (permalink) Old 01-23-2017, 01:24 PM
Pufferman's Avatar
+1 negative crankcase
2010 2500 6.7 4x4. Auto. MCSB. XRT PRO. FLO-PRO 5" TBE.
Pufferman is offline
