Egr standpipe delete - Page 2 - Dodge Cummins Diesel Forum
 7Likes
post #13 of 34 (permalink) Old 01-08-2017, 09:25 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
Originally Posted by thornton weldin View Post
Reason I ask, mine had some dried coolant around it like it had been slowly weeping. Then the other day, I found some fresh that had been pushed out of it after I got on the truck a bit hard.
I put a hose clamp on it and all is good, just wondering exactly what the purpose of that line. I'm thinking it's an overflow also, if the truck can't circulate coolant quick enough, it will return it?!?
Ya I bet its for relieving thermal expansion from within the radiator.
Wrapped matte metallic charcoal, 2015, Megacab, Laramie, 3500 SRW, 68rfe, 2" leveling kit, 35x12.5r22 atturo mt, Hardcore off road 22x12 wheels, -44 offset, 2nd gen steed speed t4 manifold, s366, proudly tuned by
White, 1998 12v, 47re, 3500 DRW, sx-e 363, 5x.018, S&B CAI, 4" turbo back, no fuel plate, afc ff, tc lock up switch
JMCustoms is offline
The Following User Says Thank You to JMCustoms For This Useful Post:
thornton weldin (01-08-2017)
post #14 of 34 (permalink) Old 01-08-2017, 09:40 PM
Cumminsdeere's Avatar
Originally Posted by JMCustoms View Post
Since I manufacture these, I cant go into pricing or anything like that in these threads because of the no advertising policy. So if there are any questions like that, PM me.
Wow, nice job documenting your work!
Maybe I missed something, but what is the point of the standpipe delete?
It's kind of a nice spot to bleed the air out upon refilling coolant.
You do excellent work, very clean appearance!
2008.5 2500 QCSB 6.7L 4x4 SLT Bighorn 68RFE 285/70R17 3.73
EFI Live by Anarchy, Sinister EGR delete, Stock downpipe, Flo Pro delete pipe, Magna Flow filter back 5" exhaust w/6" tip, no muffler, Intake baffle removed
Cumminsdeere is offline
The Following User Says Thank You to Cumminsdeere For This Useful Post:
JMCustoms (01-08-2017)
post #15 of 34 (permalink) Old 01-08-2017, 09:49 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
Thanks I appreciate it! The main reason is because its ugly and fairly unnecesesary. Until now, there was no product available seperate from any kit on the market to completely remove it.
The bleeder was useful but there are plenty of other ways to bleed it. The jiggle pins in the thermostat makes it pretty much a self bleeding system. So now you just have to bleed it the same way we've been bleeding our 5.9's all these years!
post #16 of 34 (permalink) Old 01-09-2017, 10:31 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
I also wanted to mention that I haven't tested fitment of this part on the earlier 6.7's (07.5-09). Im not sure if the connection is the same or not. If anyone here here would like to test this, shoot me a pm
post #17 of 34 (permalink) Old 01-12-2017, 03:05 PM
TSINND's Avatar
How do you bleed the system with this installed?
TSINND is offline
post #18 of 34 (permalink) Old 01-12-2017, 03:13 PM
BobSagetIsGod?'s Avatar
Same way you would normally.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #19 of 34 (permalink) Old 01-12-2017, 03:13 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
The thermostat has jiggle pins making it self bleeding however if you're still not sure, its pretty easy to loosen one of the plugs on the head etc
TSINND (01-12-2017)
post #20 of 34 (permalink) Old 01-12-2017, 04:41 PM
Leave the overflow cap off at idle until the thermostat opens.
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #21 of 34 (permalink) Old 01-14-2017, 11:52 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
One more bump just in case any of you own an 07.5-09 cummins and want to test that this part fits.
post #22 of 34 (permalink) Old 01-22-2017, 12:49 PM
diesel head
shifty22's Avatar
Thumbs up
nice job!!!!
2013 ram 2500 ccsb 4x4 manual trans, southbend 3250, afe intake, deleted, tuning by higher power performance
shifty22 is offline
post #23 of 34 (permalink) Old 01-22-2017, 12:49 PM
diesel head
shifty22's Avatar
sent a pm...
shifty22 is offline
post #24 of 34 (permalink) Old 01-22-2017, 01:22 PM Thread Starter
BlackedoUT Member
JMCustoms's Avatar
Originally Posted by shifty22 View Post
nice job!!!!
Thanks! All input is greatly appreciated!
