New parts for the ole girl. - Page 3 - Dodge Cummins Diesel Forum
 25Likes
post #25 of 137 (permalink) Old 02-14-2016, 11:07 AM Thread Starter
mikes 3500's Avatar
Originally Posted by BobSagetIsGod? View Post
Why are you waiting? With the trans out would be easiest.
The transmission has been back in sence October.
2010 CC,4x4 DRW,373,(2nd g56),Stock-ish
mikes 3500 is offline
post #26 of 137 (permalink) Old 02-14-2016, 12:57 PM Thread Starter
mikes 3500's Avatar
I'm gonna back up a little bit.
Before I first started the truck I left the injectors unplugged and rolled the engine over for about 20 seconds. 2 times. I hate to run the starter any longer and heating up the wiring. She was trying to fire without the injectors. (Compression ignition )
It never showed pressure but plugged in the injectors and fired it up and had pressure quick. From my past I've never let an fresh build just idle, so I ran it up to1400rpms for 5minutes and ran it again today.
post #27 of 137 (permalink) Old 02-14-2016, 02:16 PM
BobSagetIsGod?'s Avatar
Shoulda done the coolant bypass then.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #28 of 137 (permalink) Old 02-14-2016, 03:25 PM Thread Starter
mikes 3500's Avatar
I wish I knew then what I know now. Bob you r invited to come n help. Bring the PB blaster
The ole girl is broke in good enough
post #29 of 137 (permalink) Old 02-14-2016, 08:41 PM Thread Starter
mikes 3500's Avatar
Since 6 o clock this evening it's snowed 4". Hopefully tomorrow the roads will be clear for our first test ride. But, from the driveway test, WOW what a difference!! I can't wait to see what the dyno numbers are going to be!!
post #30 of 137 (permalink) Old 02-14-2016, 08:46 PM
TWR
TWR's Avatar
I think i can see your driveway test
2010 Ram Dually Laramie 3500 4x4,Mini Max, OD tune, S@B Air Box, Kenwood DNX9980HD, 2 10 "JL Subs/Kicker 1000.1 DX, Extang Solid Fold, Bushwacker Pocket Flares, 22.5 accurides, Snow Water/Meth mpg/max, 40 led lightbar, 8 inch BDS Longarm
TWR is offline
post #31 of 137 (permalink) Old 02-15-2016, 09:20 PM Thread Starter
mikes 3500's Avatar
We took the ole girl out,15 mile round trip. The roads were nasty wet, raining all day with snow on the ground. Today I ran the truck another 20 minutes at 1400rpms. Before I took it out. Their is no haze,with the 200hp nozzles, I was kinda worried about that. With 87,770miles of the ole girl, it is the best she has ever been. The response is very quick, the egt's are close to the same. My drive pressure might be up a little,but on such a short run its hard to say. And yes I've have smoke, wish I didn't. I think it's spooling sooner, faster, harder, it's easy to spin the tires in 6th gear. We can't wait untill tomorrow, we are going to town!!
post #32 of 137 (permalink) Old 02-16-2016, 08:14 AM
With the injectors being relatively higher mileage did you get them tested before the nozzle change?
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #33 of 137 (permalink) Old 02-16-2016, 03:32 PM
Sub'd to follow
2011 CC/LB 3500 DRW 3.73 2wd Auto, EFILive - Anarchy Tuning, Deleted
1400ho is offline
post #34 of 137 (permalink) Old 02-16-2016, 09:31 PM Thread Starter
mikes 3500's Avatar
No injector testing. I've always ran a fuel additatve, me think'n the extra lube helps.
100mile test. My egt's run 650 @ 65mph a little more if I'm going up a incline a little less if I'm going dn/hill.
If I try to maintain 10lbs of boost I've got 11or 12lbs of drive pressure.
Now keep in mind I run my mini on preformance all the time timing on4or5. With MCC from tomey.
Sprice69 likes this.
post #35 of 137 (permalink) Old 02-16-2016, 10:22 PM
Sounds like drive pressure isn't an issue, imagine that.
Did you at least have the nozzles balanced to the bodies?
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #36 of 137 (permalink) Old 02-17-2016, 12:29 PM Thread Starter
mikes 3500's Avatar
No nothing like that bob. But I did have 2 other sets of eyes when I installed the nozzles. I had my bench around vice cleaned up and laid towels around it just in case we dropped a puck. All I can say is.... You better not drop one!! We laid one of the old nozzles down on the rags, didn't know the puck was still attached with a drop of fuel. We found it but it made me second guess myself with only 1more nozzle to finish. So we pulled them all back down again to be 100% they were right. I heard they were small, this is false. They are tiny!! I was going to take pic's, but all this that I'm doing to my truck has been done 100s of times and theirs enough pictures already out there.
