Big Block 8.9L 2011 Ram Build - Dodge Cummins Diesel Forum
 314Likes
post #1 of 586 (permalink) Old 01-07-2016, 03:47 PM Thread Starter
Supporting Vendors
Calibrated Power's Avatar
Being the gluten's for punishment that we are, CPS has decided to test the old 'There's no replacement for displacement' adage on this 2011 Ram.
The truck is a 170K mile 2011 Cab and Chassis that we've used to develop our emissions equipped tuning. After reaching 505rwhp and putting the Aisin just about to its useful end we've decided to retire the 6.7L powerplant in favor of its big block counterpart.
Here she is before we initiate our shenanigans.
The Donor: A freightliner M2106 Businessclass will offer its heart for transplant.
The build will retain common rail fuel injection and hopefully a decent amount of driveability. Our goal is to build a very high horsepower truck that spools quickly and is somewhat more reliable than a very high horsepower ISB.
Facts about the 8.9L Cummins
1. It's heavier than the 6.7 ~500lbs (per cummins)
2. It's 3 inches longer than the 6.7
3. It's taller and wider as well
4. Forged crank, big rods, and 2 piece monotherm style pistons (stock)
5. 540 cubic inches!
6. The control and fuel system isn't that much different than a 6.7
7. Needs an adapter plate unless using SAE #2 compatible trans
8. 14mm head bolts... stock
9. Wet sleeve engine, potential to go 47/8ths bore (640 cubic inch!)
First thing- Get our Freightliner running and see where it's at.
Guess we have a good reason to tear it down now... hah. .
More to come.
Nick
CumminDreamz likes this.
Calibrated Power Solutions
Setting the Standard in Emission Equipped Tuning
Clean, Smokeless, Reliable Power
Cummins/Duramax/CaseIH/Deere/New Holland
815-568-7920 Ext 2126 Jim Rendant
Calibrated Power is offline
The Following 7 Users Say Thank You to Calibrated Power For This Useful Post:
banshee1545 (06-13-2016), Broaner (02-26-2016), Chevokeeman (03-02-2016), komatsu3816 (01-10-2016), RJ_Cummins (05-19-2016), runit02 (02-20-2016), Saetkae (12-16-2016)
post #2 of 586 (permalink) Old 01-07-2016, 04:07 PM
World Champs!!!
MoparProud's Avatar
Ok. Well, I'mma watch.
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
The Following 2 Users Say Thank You to MoparProud For This Useful Post:
12valvedriver (06-10-2016), runit02 (02-20-2016)
post #3 of 586 (permalink) Old 01-07-2016, 04:15 PM
Sub for this one. Going to be sweet
Terminator-06 5.9 CCSB
66/84 twins, dual fuelers, firepunk stage 2 comp trans
Project Aftershock 2012 CC/LB 2wd. 750hp tow rig build
Twiztedmetal3 is offline
post #4 of 586 (permalink) Old 01-07-2016, 04:29 PM Thread Starter
Supporting Vendors
Here's a shot of the engine just before it makes its way out of the M2.
And a perfectly good 6.7
Big block getting prepped for initial fitment in the 2011. You can see the gearcase location on the lower drivers side where the air compressor drive is located. We're going to have to remove this openning to clearing the steering gearbox. More on this in the next picture.
And up til today where we're fabricating engine mounts for the 8.9 because it doesn't come with any mounting locations on the side of the block.
Nick
The Following User Says Thank You to Calibrated Power For This Useful Post:
2drwagon (03-11-2016)
post #5 of 586 (permalink) Old 01-07-2016, 04:45 PM
Looks like a interesting build, keep us posted on the details
1998 5.9 24V Stock
roscoe200 is offline
post #6 of 586 (permalink) Old 01-07-2016, 06:05 PM
HawkEye Mihawk's Avatar
2012 2500 ST CCLB HO - EFIlive by Anarchy Diesel BMP s464 kit 5" exhaust Edge Evolution CTS2 (for monitoring) Glowshift boost & drive pressure gauges COOPER ATP 285-70-17 ON AMERICAN RACING 910
HawkEye Mihawk is offline
post #7 of 586 (permalink) Old 01-07-2016, 06:24 PM
Got Torque's Avatar
Wow. I always wanted to see this happen
05 2500 NV5600. 700hp---AW Whatever!!! Nobody really cares what I say anyway!!!
Got Torque is offline
post #8 of 586 (permalink) Old 01-07-2016, 07:42 PM
UncleBubbles's Avatar
That is an ISL9. Being an I.S. (Interact system) fuel system, which follows the same principals as all cummins IS engines, ISX, ISB, etc.should be a fairly simple swap. It won't like rpm much because of its huge stroke of 5.65 inches, but the torque will be there lol. Do a QSK19 next! 19 liters!
GNBEAST likes this.
A very tired, falling apart, 2008 Dodge Ram 2500, 6.7/ZF6, 4x4, QC/LB, EFI Live and a SouthBend.
Nothing is foolproof to a sufficiently talented fool.
UncleBubbles is offline
post #9 of 586 (permalink) Old 01-07-2016, 07:51 PM
Nutty Jeeps's Avatar
well I shall watch this as well
2012 Ram 2500 Black Limited Mega - deleted, EFILive w/ trans tuning, CTS2, GDP S-3, 5" MBRP Leveled 20X10 Fuel Maverick's -24 offset 35" Trail MT's
2013 Can-AM 1000 XMR
Nutty Jeeps is offline
post #10 of 586 (permalink) Old 01-07-2016, 10:02 PM
700xxrider's Avatar
Subscribed!
2006 cclb, built auto, s366, industrial injection 100 horse injectors, bluegrass diesel tuned 704/1245
700xxrider is offline
post #11 of 586 (permalink) Old 01-07-2016, 10:15 PM
99grinder's Avatar
Omggggg
2012 black RCLB G56 4X4 deletes efi by anarchy,s467.7 Pfeifer's performance,FPE, "The Handshaker"
99 green ECSB SOLD 5spd big air big fuel big power. "Go Green"
99grinder is offline
post #12 of 586 (permalink) Old 01-08-2016, 12:09 AM
evildiesel's Avatar
Definitely going to watch this.
evildiesel is offline
