Big Block 8.9L 2011 Ram Build - Page 3 - Dodge Cummins Diesel Forum
 313Likes
post #25 of 586 (permalink) Old 01-09-2016, 09:27 AM
malibu27's Avatar
That's awesome guys!
2010 lotta extras
malibu27 is offline
post #26 of 586 (permalink) Old 01-09-2016, 09:40 AM
semperfidoordie's Avatar
Excited to see this done. Great start
2006 CTD MegaCab 4x4 128k and counting
USMC/OIF Veteran 2005-2014
semperfidoordie is offline
post #27 of 586 (permalink) Old 01-09-2016, 09:45 AM
TWR
TWR's Avatar
Looks like fun!! What trans are you planning on using?
2010 Ram Dually Laramie 3500 4x4,Mini Max, OD tune, S@B Air Box, Kenwood DNX9980HD, 2 10 "JL Subs/Kicker 1000.1 DX, Extang Solid Fold, Bushwacker Pocket Flares, 22.5 accurides, Snow Water/Meth mpg/max, 40 led lightbar, 8 inch BDS Longarm
TWR is offline
post #28 of 586 (permalink) Old 01-09-2016, 10:01 AM
Lifetime Thread Hijacker
Ontario Trucker's Avatar
I'll watch
Gerry
2011 white Ram crew cab short box, Viair, train horns, Amp bed step
2010 Sandpiper 345RET, 40ft 5th wheel
Ontario Trucker is offline
post #29 of 586 (permalink) Old 01-09-2016, 11:24 AM
mdill's Avatar
Cant wait for updates on this... pictures or links please! *subscribed*
11' - 68RFE-ARP625s -MBRPTBE - PUSHERair EFI LIVE by Screamin' Diesel Performance
mdill is offline
post #30 of 586 (permalink) Old 01-09-2016, 11:30 AM
should be interesting.
04 QCLB. 48re, 4x4.
08 mega g56, 4x4, under went weight reduction process.
Killer223 is offline
post #31 of 586 (permalink) Old 01-09-2016, 11:35 AM
Ducati M.
DMan1198's Avatar
I can say from experience those water pumps are not the easiest to do when you try to leave the fan/bracket on the engine. I would've saved myself about 15 minutes if I would've just unbolted the fan in the 1st place.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
v2 Finally doing stuff
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
Instagram:
DMan1198 is offline
post #32 of 586 (permalink) Old 01-09-2016, 05:13 PM
N1NJ4ON3R's Avatar
I'll step in as well.
-2008 6.7l QCLB 4x4,g56,J-67(23ME),valair DD,64.5/72/14,2nd gen mani,arp 425's,boost and pyro... -1993 W250 CCLB...
-1996 brewed s14 w/ 386 rwhp & 341 rwtq @19psi twinscroll baby!!!(gt3076r)
N1NJ4ON3R is offline
post #33 of 586 (permalink) Old 01-09-2016, 10:53 PM
Subscribed
2014 2500 Outdoorsman 6.7 CC SB
98hd is offline
post #34 of 586 (permalink) Old 01-09-2016, 11:19 PM
Oil Burner
Tsimayn's Avatar
How many horses / ft-lbs are you shooting for? Will you be trying to get any additional revs out of it?
04.5 4x4 cclb, utility bed dually, nv5600, mostly stock
06 4x4 megacab, 10" suspension lift, fox 2.0, billet 48re, air dog 165, edge j w/a, banks intercooler and ram air
Tsimayn is offline
post #35 of 586 (permalink) Old 01-09-2016, 11:35 PM
08 Cummins
KhakiCummins's Avatar
Are you going to adapt it to run the stock 6.7L ECM or can you custom tune the 8.9L ECM?
Duane
2008 Ram 3500 QuadCab
Hamilton 103# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
2014 Jetta TDI 6 SPD Manual
KhakiCummins is offline
post #36 of 586 (permalink) Old 01-10-2016, 12:32 AM
JoshZ28's Avatar
Originally Posted by UncleBubbles View Post
That is an ISL9. Being an I.S. (Interact system) fuel system, which follows the same principals as all cummins IS engines, ISX, ISB, etc.should be a fairly simple swap. It won't like rpm much because of its huge stroke of 5.65 inches, but the torque will be there lol. Do a QSB19 next! 19 liters!
You mean QSK?
2005 3500 4X4 SRW. Bully Dog with Crazy Larry, Magnaflow, 6" Superlift, Bilstein 5100s, 37x13.5x20 Toyo's, Leer 100XQ
JoshZ28 is offline
The Following User Says Thank You to JoshZ28 For This Useful Post:
KNOX (01-27-2016)
