dual wheel conversion - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 1Likes
post #1 of 20 (permalink) Old 01-21-2012, 09:43 PM Thread Starter
mikenacarato's Avatar
iTrader Score: 6 reviews
Ive got a 2011 4x4 mega and i was curious to know what is needed to convert over to a dual rear wheel setup. ive heard flares and wheels are all i need but im a bit skeptical. any info will help, thanks!
2011 2500 Megacab
2004 3500 DRW
mikenacarato is offline
post #2 of 20 (permalink) Old 01-21-2012, 10:09 PM
iTrader Score: 4 reviews
I do believe you are going to also need the front spacers for the wheels as well.
Do you have a 2500 or 3500? You should fill out your signature
I am wondering because if you have a 2500 then you will have TPMS (tire pressure monitor sensors). Not sure how that will work out. Maybe just run on the fronts normally and inside rear tires?? Not sure.... But something to consider. Or h&s with tpms disabling feature.
Previous Cummins:03 QCSB 47RE/2011 CCLB G56/2005 RCLB DRW G56/1995 RCLB 47RH/2006 RCLB G56/2015 EcoDiesel QCSB/2012 CCSB/2016 SCLB Powerstroke
Current:2015 2500 RCLB 68RFE 4x4 6.7 SLT
tj200 is offline
post #3 of 20 (permalink) Old 01-21-2012, 10:13 PM Thread Starter
i do have a 2500 with the h&s mini maxx already installed.
2011 2500 Megacab
2004 3500 DRW
post #4 of 20 (permalink) Old 01-22-2012, 11:40 AM
NC Hauler's Avatar
.....Believe the axles are different if I'm not mistaken....I doubt the only difference between a 2500HD and a 3500 Dually is 4 tires instead of two...I know there are more leaf springs, and again, though I might be wrong, I think it's a different axle...Guess if you find a 3500HD DUALLY axle, wheels, spring pack, shocks etc...you could swap out, but what about wheel wells?
2016 Ram 3500DRW/CC/LB/4X4/4:10/Aisin/Longhorn/rear air assist, Peal White
2016 Jayco 4112 flood totaled..looking for another one
USAF Viet Nam Vet
NC Hauler is offline
post #5 of 20 (permalink) Old 01-22-2012, 07:55 PM
baron37075's Avatar
Mike, I'm wondering why you're wanting to make your SRW into a DRW.
Also, hope to see you this coming Saturday in Goodlettsville, TN Signups for Jan 28, 2012 TN GTG @ Hooters!
2012 RAM 3500 MEGA CAB LARAMIE 6.7L 4x4 4.10 Cruiser Alloy 22x9.5 "Switchblade" 904-MB +30mm Offset 6.5" backspace Nitto Terra Grappler 285/55R-22 Hypertech Speedo Calibrator Firestone Air Bags/Air Compressor/Wireless Remote Top Gun Customz Control Arms Amp Research Power Steps/Bed Step RetraxPro Bed Cover Roadmaster Anti-sway Mag-Hytec Rear Diff Cover Amsoil 75W90 Husky Liner Front/Rear Mud Guards Monster 4x6x18 Exhaust Tip Craven Speed Stubby Pullrite SuperGlide 18K BD SBS Tuff Country Traction Bars Putco Interior Lights Bistein HD Shocks
baron37075 is offline
post #6 of 20 (permalink) Old 01-22-2012, 10:49 PM Thread Starter
i would go but i will be racing in sebring, fl this weekend. ill plan on attending the next event for sure!
my reason for doing this conversion is i will be getting a larger gooseneck trailer and instead of upgrading to a new truck (spending way to much) i can just convert to a dual wheel setup. i know the suspension leafs are different but i do have airbags and according to the load of my trailer and the ability of the bags and leafs i have it should work just fine. the dealer also said my truck has the same rear end as a 3500 ( dont know if it was an upgrade or standard that way)
so my thinking is some wheels, flares, and other small things to do a conversion is a lot cheaper than a new truck.
2011 2500 Megacab
2004 3500 DRW
post #7 of 20 (permalink) Old 01-22-2012, 11:52 PM
Lawdog's Avatar
I did my 2006 Mega 2500. My truck had the 11.5 AAM rear axle but the Duallly axle is wider. I found someone wanting to swap rear ends as he wanted to go to a SRW. I drove from Detroit to Atlanta GA to do the swap but had also had a bed lined up there that was matching color. We swapped rear axles but kept the same brake calipers. We undid the lines and hung them so no bleeding was necessary. ( Except maybe a knucke or 2) Bought front factory adapters off e-bay and wheels off craigslist. I only used the airbags for mine as well. I love the truck and will never want to tow anything big with a SRW truck again.
Drove a friends 2011 F350 SRW towing his 40ft race trailer g'neck and mine is way more stable with our 40' trailer
Looking at selling now and going to the 2012 Mega Dually
2016 Ram 1500 CC Limited Black with 3.92 and Ram Boxes
SOLD:
2012 Black 3500 Laramie Mega Cab DRW, auto, stock, Max Tow w/ 3.73
563 Motorsports Snocross Team
Lawdog is offline
post #8 of 20 (permalink) Old 01-23-2012, 12:08 AM Thread Starter
if i cant find a rear axle i could probably find a main axle tube and two axle shafts. it cant be too hard to put this together.
does anyone know of a place to get wide flares?
2011 2500 Megacab
2004 3500 DRW
post #9 of 20 (permalink) Old 01-23-2012, 12:15 AM
Lawdog's Avatar
You can do a Dually conversion spacer kit from Arrowcraft. I know people that have used them (Actually the second set ever made by the company way back when) very good quality. I was going to use them until I found the person to swap axles.
SOLD:
Lawdog is offline
post #10 of 20 (permalink) Old 01-23-2012, 12:18 AM Thread Starter
thanks! thats not too bad.
now about the flares...someone has to know!
2011 2500 Megacab
2004 3500 DRW
post #11 of 20 (permalink) Old 01-23-2012, 11:21 AM
How about 3rd gen mega dually flares?
2010 3500 Crew Cab Long Bed Laramie 4x4 4.10s
DF5152 is offline
post #12 of 20 (permalink) Old 01-23-2012, 11:27 AM
UNDER-PRESSURE's Avatar
iTrader Score: 5 reviews
This place might be able to help?
Link >>> DuallyFendersUSA.com
His: '12 3500 SRW Mega 4x4 6.7L HO, 4.10's, Stock
Hers: '06 2500 Mega Cab 2x4 5.9L, Not Stock
UNDER-PRESSURE is offline
