2014 Ram HD to have 6.4 Hemi - Dodge Cummins Diesel Forum
4th Gen Non-Cummins Powered RAM General Discussion Discussion of RAM Specific Eco-Diesel and HEMI. NO ADVERTISING.
 3Likes
post #1 of 906 (permalink) Old 07-10-2013, 04:25 PM Thread Starter
Can you imagine the gas milage that the 6.4 Hemi will get. Nice to have options but not for me
See below link
http://www.allpar.com/trucks/ram/2014-heavy-duty.html
2014 Ram 2500 CC/ 4x4 Laramie/6.4 Hemi/66RFE/3:73 Anti-Spin/ maximum Steel
2013 Ram 2500 CC/4x4 SLT/BH/6.7 CTD SOLD
2012 Ram 2500 CC/4x4 SLT/BH/6.7 CTD SOLD
2014 Wolf Pack 28WP Limited TT TH 7500 lbs Dry
2014 Polaris Ranger XP 900
2014 Polaris Sportsman 570 Touring
2012 Mazda 3i Touring 40 mpg
Turbo Crazy is offline
post #2 of 906 (permalink) Old 07-10-2013, 04:31 PM
Moto Evolution's Avatar
I imagine that it will get just as good or better than the current 5.7 liter.
2012 Ram 2500 Laramie Crew Cab 4x4 6.7L Auto
Moto Evolution is offline
The Following User Says Thank You to Moto Evolution For This Useful Post:
w tx. iceman (07-10-2013)
post #3 of 906 (permalink) Old 07-10-2013, 04:38 PM
Scott_85's Avatar
Could pass everything but a gas station !!
Scott_85 is offline
post #4 of 906 (permalink) Old 07-10-2013, 04:42 PM Thread Starter
Which isn't that good.
That thead also said that 2014 2500s will be going to a 5 link coil over suspension in the rear. That seems hard to believe that the 5 link could handle the same payload. My Hemi 1500s wold squat pretty easy. Maybe the help of the new air bag suspension system will make it all work. Ram is not taking a break,that's for sure.
Carl847 likes this.
post #5 of 906 (permalink) Old 07-10-2013, 04:45 PM
→ True Blue ←
67guzzler's Avatar
Moto Evolution is right -- It has a lot of enhancements. I wouldn't be surprised if it does as well as the 5.7L does in regards to MPG:
From Allpar:
The 6.4 liter Hemi truck engines
"For trucks, durability and a broad torque curve take priority over sheer horsepower. Taking cues from Mopar engineers of the distant past, the designers used sodium-filled exhaust valves and tougher valve seat materials; because of heat issues, they also used aircraft-grade stainless steel exhaust gaskets and fasteners, and oil jets for cooling the pistons. A robust high-volume oil cooler and revised PCV system (integrated in the intake manifold) increase oil efficiency. Computational fluid dynamics were used to optimizing the cooling circuit.
An active dual-runner-length intake manifold helps boost both low-end and high-end power, an old Mopar trick based on maximizing the natural “supercharger effect” of the manifold.
The engine has a cooled EGR system for greater efficiency, cylinder deactivation for economy, PVC integrated into the intake, and a floating pin on the systems. The engine has a cast iron block and forged steel crank. At launch on 2014 Rams, it was hooked up to the 66RFE automatic transmission (with the Aisin optional).
On Ram chassis cabs with a gross vehicle weight rating over 10,000 pounds, the 6.4 is rated at 367 hp at 4,600 rpm."
I'm personally interested in it.
-Guzzler
Carl847 likes this.
2017 2500 Crew 6.4L HEMI™ 66RFE 4x4 Laramie / "
2013 3500 Crew CTD G56 SRW 4x4 Tradesman /
/ Sold
2010 2500 Mega CTD 68RFE 4x4 Laramie /
/ Sold
"Please don't complain about trivial & inane things about your truck."
67guzzler is online now
post #6 of 906 (permalink) Old 07-10-2013, 05:06 PM Thread Starter
From Allpar:
-Guzzler
My 2012 Hemi 4wd would never get 18 mpg on the highway like the window sticker Said .My 2500 gets better gas milage than my Hemi did and I can pull anything. I do miss that soft ride on the 1500 with the 5 link rear end. That's all i miss.
post #7 of 906 (permalink) Old 07-10-2013, 05:15 PM
→ True Blue ←
67guzzler's Avatar
I have a "wait and see" attitude. I'm not ready to judge based upon any of the 5.7L implementations. It might be dog or it might not.
Time will tell.
-Guzzler
/ Sold
/ Sold
post #8 of 906 (permalink) Old 07-10-2013, 06:19 PM
Pot Stirrer
Tuffguy707's Avatar
Time will tell.
-Guzzler
I agree 100%. Only time will tell. It's not like the old days where the bigger engines got horrible gas milage. If that was the case there wouldn't be the 6.4. Ram knows people are concerned with milage. Also just because its a bigger engine doesn't mean it will get worse milage. My 2000 ram I had had the v-10 and it got better milage than my uncles 360 in the exact same truck.
2013 3500 srw Laramie limited 4x4 crew long bed black on black aisin 2" leveling kit, 5% window tint. Hornblasters train horns. Bone stock and staying that way
Previous rams 2000 2500 slt + qc lb 4x4 v-10, 03 qc lb 2500 4x4 hemi Laramie, 07 3500 qc lb 4x4 5.9 ctd Laramie. All have been black
Tuffguy707 is offline
post #9 of 906 (permalink) Old 07-10-2013, 06:36 PM Thread Starter
Time will tell.
-Guzzler
Well we can't say that Ram is not giving us options in the Ram engine dept. I think only three of the below options are for the HD series. The last 3. Correct me if I am wrong.
3.6
3.0 Turbo Diesel
4.7 (dog,should discontinue)
5.7
6.4
6.7 Turbo Diesel
post #10 of 906 (permalink) Old 07-10-2013, 07:17 PM
→ True Blue ←
67guzzler's Avatar
Yup. And I 100% understand that this is the CUMMINS Forum. I'm keeping the 2010 as it's basically a show truck through and through without a blemish. This would be my daily driver (the 6.4L if I got it). So I'm interested. I hope the refinements and execution are good because I think there is a market for a well-done heavy duty gasser and I think 350 cubic inches (5.7L) is a lot to ask of when you want to move heavy stuff.
-Guzzler
/ Sold
/ Sold
post #11 of 906 (permalink) Old 07-10-2013, 07:54 PM
FF1063's Avatar
It's a 400+ HP V8, sounds like a choice many like me have been waiting for. Hope it's launch is a good one. The added purchase/ownership costs of the CTD does make a new Gasser more attractive these days, at least Ram and I think so.
2014 RAM 3500 4X4 DRW CTD 24V
1998 RAM 3500 4X4 DRW CTD 12V - Gone !!
FF1063 is offline
The Following 2 Users Say Thank You to FF1063 For This Useful Post:
Prostar197 (12-31-2013), Raw Dodge (02-27-2014)
post #12 of 906 (permalink) Old 07-10-2013, 08:03 PM
→ True Blue ←
67guzzler's Avatar
Just stumbled upon this PR junk but it's interesting.
-Guzzler
/ Sold
/ Sold
