Adding 52 gallon fuel tank in rear of 5500 - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 6 (permalink) Old 02-07-2017, 06:18 PM Thread Starter
What is required to add a 52 gallon OEM fuel tank to the rear of a 2016 5500 that was special ordered with 22 gallon tank only? We do not want a tank on the bed because our equipment wont fit then.
Kenny5500 is offline
post #2 of 6 (permalink) Old 02-07-2017, 08:15 PM
Do you want to add the tank or replace your 22 gal tank?
2015 RAM 4500, 84" C&C with aisin trans, Raceme ultra, custom ( Home made) flatbed, ultimate woods farm truck
Giddings is offline
post #3 of 6 (permalink) Old 02-07-2017, 09:47 PM Thread Starter
Either way. Which ever is easier. 52 or 74 gallons will work for me.
post #4 of 6 (permalink) Old 02-09-2017, 07:41 PM
JAKESRAM5500's Avatar
I would say switching to the 52 and dropping the 22 is the best and fastest way, adding a tank requires reprogramming of the trucks default calibration. I have both tanks in mine, the rear 52 gal tank is held in place with a skid plate on the bottom, You should be able to get all the parts you need from either ram or a salvage yard.
2015 RAM 5500 Cummins ,Galion 4yd stainless steel dump, Aisin, 4.88's, Dual fuel tanks, Dual Alt, Working Monster!
JAKESRAM5500 is offline
post #5 of 6 (permalink) Old 02-15-2017, 10:07 AM
One issue with changing the tank that cannot be fixed. The Distance to empty screen cannot be changed because that is programmed into the vehicle at the factory and cannot be updated. And the fuel pump module assemblies are different between the midship and rear tanks. One other option is to go to an aftermarket midship tank like Transfer Flow. It comes in kit form so all your existing lines will connect. I think they are 42 gallons.
dp5l66 is offline
post #6 of 6 (permalink) Old 04-12-2017, 12:57 PM
74 gallons...wow!
-Jason
94 Regular Cab SRW 2wd 5-Sp 75k mi
nomorotors is offline
