2015 Alignment Specs? - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 9 (permalink) Old 01-02-2017, 12:22 PM Thread Starter
deminimis's Avatar
Hi,
Noticing some right outside tire wear. Left looks good. Under 18k on the clock and tires (Michelin) under 8k. I understand the factory specs are pretty broad, so worried the shop will say I'm in spec. Anyway, if someone has the ideal specs figured out, I'd love to hear it. All stock front suspension and under front axle cap (although not by much). Thanks.
deminimis is offline
post #2 of 9 (permalink) Old 01-02-2017, 12:35 PM
DodgeMech's Avatar
do you rotate the tires?
the specs are pretty well what they've always been
toe .10 and .10 for a total of .20, caster is near 4.5 on both sides, and camber, i believe is supposed to be maybe .5 on both sides
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #3 of 9 (permalink) Old 01-02-2017, 12:42 PM Thread Starter
deminimis's Avatar
Thanks. Nope, don't rotate, so the issue is clearly with the front right. Thanks for the specs. I do recall reading a while back that some run with zero toe on these, but not finding that now (on a phone, so not doing my best forum searching).
post #4 of 9 (permalink) Old 01-02-2017, 07:45 PM
DodgeMech's Avatar
if you rotate, every 3-7k, you'll notice a lot less wear on the front tires
strait front axles are very, very hard on tires, especially if you tow with the truck, or have a camper like you do
and what sucks about the alcoas you have, is you have to break down the tires to properly rotate them
i'm gonna say you should just keep them rotated...though the toe may be out a bit, causing the one tire to feather...but on a set up like these are, where there's one bar connecting both knuckles, usually both tires feather from a toe issue
and if it's that the camber on that side is slightly out, there's not much to do to fix that, since the angle of the "C" at the end of the axle is what sets it
-CJ
02 Taco Prerunner
06 Jetta TDI
post #5 of 9 (permalink) Old 01-02-2017, 08:17 PM Thread Starter
deminimis's Avatar
Thanks. Rotating is just not an option (diferent tires on front for pulling out of snow. Not changing rears until they're finished). Thanks.
post #6 of 9 (permalink) Old 01-03-2017, 01:52 PM Thread Starter
deminimis's Avatar
Disregard. The specs I posted were not accurate.
2015 5500 Laramie 197" WB w/ Bradford [Poorly] Built Flatbed.
post #7 of 9 (permalink) Old 02-20-2017, 06:47 PM Thread Starter
deminimis's Avatar
Got the specs from the dealer. Good thing. Alignment shop didn't have the correct ones.
Toe on the right was .5" off. Nice.
I'll have to center the wheel as they never seem to get that right. At least it's easy (once it's not all snow and mud in my driveway). Shop didn't put one of the center caps on all the way. Nice surprise when i got home. Claim they're ordering a replacement for me. Uggh.
post #8 of 9 (permalink) Old 04-21-2017, 08:51 AM
https://www.thurenfabrication.com/te...-handling.html
2013 3500 CCLB, Larmie Maximum Steel, 4x4, G56, C&M Flatbed, Hardway, CSP4, SouthBend 3250DD, FloPro 4", Flowmaster HushPower, 35" Kanati Trail Hogs, No lift.
WVracer821 is offline
post #9 of 9 (permalink) Old 04-21-2017, 09:59 AM Thread Starter
deminimis's Avatar
Interesting read. Thanks for posting.
