DEF/DPF Delete 2015 - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 29 (permalink) Old 12-22-2015, 08:37 AM Thread Starter
DEF/DPF Delete 2015
Has anyone deleted their 2015 Rams or know where to purchase the gear to carry it out. No need to tell me about warranty as I live to far from a dealer to give a anymore.
cgnlf is offline
post #2 of 29 (permalink) Old 12-22-2015, 09:04 AM
BobSagetIsGod?'s Avatar
DEF/DPF Delete 2015
Rollinsmokediesel.com
Use coupon code RSD for a discount at checkout.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #3 of 29 (permalink) Old 12-23-2015, 02:07 PM
After running different tunes and set ups from vendors that run efi live, the only person that can make your truck run code free/bump up the power/bump up the mileage is HPP. I have spent many times going to the dealer to find out what codes I was getting and giving to the tuner to help diagnose the problems I was having. After 6 ish months of not gaining anything, I talked to HPP. Jonathon sent me an autocal with his tune to try out and next thing you know all my check engine codes went away, and my truck actually had ALOT more power. I could tell when I flipped the switch.
The other guys have the 25/3500s figured out, but HPP has the cab and chassis figured out. I wasnt the only guy having the same issues either. After I tried HPP, he did the same thing and he finally had a grin as well.
2013 Ram 5500 SRW pickup auto 4x4, 4.88 gears, Kelderman air suspension, extreme outback compressor, rickson wheels, toyo 285/70/19.5 M608Z, transfer flow 40g tank, blue lake front and rear winch bumpers, milemarker hydro winch. EFI by HPP, Flo pro muffler, 36x13.5x19.5 super swamper IROK's. The ramman locking hubs, pacbrake LoadLeash, arp 425's,
ridofpwrstroke is offline
The Following User Says Thank You to ridofpwrstroke For This Useful Post:
StealthDiesel (12-28-2015)
post #4 of 29 (permalink) Old 12-23-2015, 05:10 PM Thread Starter
Still looking into this, So far I found a place that sells everything required. Question I have for you all is this. They are telling me that I need to use the Bully Dog GT with lock out cable, which im fine with only think is they are selling it for $1300 and I have price it at other places for $550. Would theirs have a special program for the delete or can any of the GTs do the same thing?
cgnlf is offline
post #5 of 29 (permalink) Old 12-23-2015, 05:13 PM Thread Starter
2007.5-2015 Dodge Cummins Bully Dog DPF Delete Tuner BUL 6.7L 40428
$1,299.99
1
Add to cart
Description
Product Description
NOW AVAILABLE 2013-2015 DODGE TUNING MUST HAVE UNLOCK CABLE (Does not support cab and chassis)
2010-2013 Cummins Bully Dog DPF Delete Tuner
Tow – 56hp/114tq
Performance – 80hp/158tq
Extreme – 121hp/250
14-15 Cummins
Tow – 40hp/80tq
Performance – 70hp/110tq
Extreme – 110hp/197tq
• 4 on-the-fly settings
• 2.5” Color screen
• Allows removal of DPF/Cat, EGR & Urea injection
• Built in gauges & safety features
• Precisely tune engine with HP gains
• Remove/Adjust top speed limiter
• Speedometer recalibration for use of non-stock size tires or gearing
• Enable/Disable factory “special features”: High idle, fogs w/highs, seat belt chimes, daytime running lights, etc.
• Automatic safety back-down: Controlled by EGT, Boost, Trans. Temp, and Coolant Temp
SKU: BUL D6.7L 40428
Thats from their site, anyone know?
cgnlf is offline
post #6 of 29 (permalink) Old 12-24-2015, 10:28 AM
mustarogz's Avatar
deleted my 15, bought eveything from xtreme diesel black friday sale, bully dog/gorilla/unlock cable/5in afe straight pipe, runs flawless and more power even with the no power tune.... very happy
H&T COLLISION!!!! WE MAKE FRIENDS BY ACCIDENT!!!
2015 CUMMINS BAP 2500 CC SB
Deleted 5in AFE Sinister egr delete 4in superlift 22x12 Forces 35's N fab steps and truxedo tonneau...
1998 12V 3500 EXT CAB DRW
5 speed 4wd blue sport 5in pipe and 22.5 alcoas
mustarogz is offline
post #7 of 29 (permalink) Old 12-25-2015, 08:51 PM
Anarchy Diesel
3brorce's Avatar
iTrader Score: 8 reviews
$1,299.99
1
Add to cart
Description
Product Description
Tow – 56hp/114tq
Extreme – 121hp/250
14-15 Cummins
Tow – 40hp/80tq
• 2.5” Color screen
Are you looking to run EFILive or just run a bullydog? If you had a pickup and just wanted a bullydog that is the one you would want but it does not support c&c trucks.
708-990-7006
Anarchy Diesel Tuning
EFI Live BETA Tester
Custom tuning with EFI Live/H&S MCC/HP Tuners/WARP/EZ Lynk
3brorce is offline
post #8 of 29 (permalink) Old 12-28-2015, 08:18 PM
Muddawgchuck's Avatar
Is EFI live the only option for c&c? RaceMe?
12 3500 CCLB 4wd DRW
H&S MM, ARP studs, Valier DD, Sinister/GDP egr delete, Flo-Pro 5" turbo back, and Vision 19.5 wheels.
Muddawgchuck is offline
post #9 of 29 (permalink) Old 12-28-2015, 08:20 PM
Efi live is currently your only option. But it's a good option to have.
post #10 of 29 (permalink) Old 02-01-2016, 11:13 PM
What did it cost u about ?
SUPRA180 is offline
post #11 of 29 (permalink) Old 02-16-2016, 03:49 PM
Repoxxx's Avatar
I have a 2013 C&C tow truck and just did the entire delete process last Friday. Glacier Diesel EGR delete kit and Raceme Ultra for C&C. Includes the unlock cable and on the fly programming with 10 power levels.
No codes and no CEL.
Seems the working fine.
1400.00 Complete with the EGR delete kit for C&C. the EGR delete kit for C&C is totally different than the 2500/3500 truck kits
2013 4500HD (C&C) Vulcan 812 Autoloader
RaceME Ultra W/DPF/EGR/DEF Deletes w/Flo-Pro Exhaust
Repoxxx is offline
post #12 of 29 (permalink) Old 08-22-2016, 10:49 PM
Are just running deletes with stock power? Or are you able to add power?
Sent from my SAMSUNG-SM-G920A using Tapatalk
twadd101 is offline
