Old 02-27-2008, 04:54 AM   #9 (permalink)
95 SLT
95 SLT's Avatar
Originally Posted by ynots57 View Post
I was just stating from my own experience a 2005 runs quieter when using an lube additive and pointing out the fact that the additive ratios used in that test on 2 cycle oil and power service diesel kleen are lower amounts then what most people normally use.
My engine does not seem to like 2 cycle oil either. I used it 3 times total and lost 3-4 mpg when I dumped last quart in at fill up (128:1). I was more worried about cat clogging than injectors. How many miles did you run 2 cycle oil before injector problems?
I do use diesel kleen every tank, my truck sits 6 months a year 8 weeks at a time.
A 100:1 mix of 2 stroke lubricates an air cooled engine.
I feel your using way to much per fill up choking full combustion.
1/2 a quart per tank would be ample.
Still better than nothing.
I feel and hear the difference adding only 1/4 quart.
I fill at a station using Diesel Max.
It has an additive.:thumbsup
'95 12V, super cab 4x4, BHAF, 400,000 +mi. pac brake, KDP retainer done, #10 fuel plate, boost elbow, DDS stabalizer, 215 Bosch injectors.
Now I have a Truck.
95 SLT is offline   Reply With Quote
