Old 02-26-2008, 03:14 PM   #4 (permalink)
ynots57
ynots57's Avatar
if you havnt tried adding extra lube to your 2004.5 + 5.9's you may be surprised with the results of doing so unless your hard at hearing. Keep in mind that the additive volumes used in the test were added to 26 gallons of fuel. The power service diesel kleen ratio used in this HFRR is 1/2 the amount you would use for a 6 cetane increase, so Im sure the lube quality would improve also. The Super Tech 2-cycle oil was tested at 200:1, typically everyone uses 128:1 mix.
05 - 2500, 4x4x6, 48re, aero, aem & other $tuff
"Many times a mans mouth broke his nose"
ynots57 is offline   Reply With Quote
