The rear disks come off without pulling the axleshaft. There are two or three clips that hold the disk on from the factory-for the assembly line. they are on the studs, so you would have to clip them off with side cutters or the rotor wont come off. the only other thing it could be would be rust holding things on.
02.5 2500 4X4 reg cab white HO 6spd
Tapped Edge Comp with TST plate and Bosch RV 275 sticks.
Stacks by Hogg innovations to roll the coal...
Hogg innovations lift pump/filter big line setup,
Multi function shifter stick,Solenoid High Idle
LED's all over, and CF stickers too!!
