sliding your plate shouldnt give you too much trouble with your trans if thats all you have done to the truck. but if you plan on upgrading your motor then you could upgrade your TC and get a shift kit check out ats. also do you kdp intake exhaust and some gauges and your trans then go for the power
97 EC, LB white, smoked cab lights, 4 inch skyjacker firestone bags and 37s on 17s. afc tuned, #0 slid where it needs to be, boost elbow @ 37lb, BHAF, 4 inch straight pipe to 6inch single stack, 100hp injectors, gauges (boost/egt) valair single 450hp 850lb ft
