Thread: Stock filter
Old 01-17-2008, 06:16 PM   #19 (permalink)
wintersucks
Originally Posted by mayfair View Post
Whoa ... do NOT re-think the FASS. You'll never find a better fuel supply pump anywhere .... PERIOD
You can either run the lines like I did in the link provided above, or if you'd like the FASS actuall DOES have ports that you can run lines to from your radiator to warm up the fuel.
So you see, FASS has you covered on all bases. I just chose a different path the heat the fuel,that's all. Get a FASS, I promise you you won't be dissapointed. :thumbsup
thanks, i will still be ordering a fass soon.
2005-2500 Quad Cab Big Horn 4x4 CTD NV5600-4" turbo back-ATS Arc Flow intake manifold-AEM Workhorse HD cold air intake-TST R37-Autometer Phantom II Pyro & Boost-single gauge column pod-SRT10 A-pillar C.I.-30
wintersucks is offline   Reply With Quote
