Originally Posted by tatkins85
hey guys i cant find a spot under my cab to bolt up my fass it wont fit anywhere? any spot that looks good ill try but the top of the fass will hit the top of the bed before the holes will line up on the brackets i have an 01/02/06 made dodge 2500 shortbed cummins where do i put this thing? the fass us the 95/150.
Short beds are the hardest of the trucks to get a FASS installed. AND also the hardest for me to explain as well.
I know the frame bracket needs to be attached to the cab mount, not the bed mount. If you need to trim the end of the bracket to clear the spring, that is fine. My suggestion is to get the frame bracket as low as you but will still bolt up. Use vice-grips to gauge where you need to put it.
I might have to wait until our 2wd short bed shop truck gets here. I can go out and look at it for reference. It, too, has a 95 Series on it.....so that should be a good comparison.
Ill post more later.....
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
