Originally Posted by wintersucks
now i am rethinking my decision to get a full FASS system, i had read on a couple sites (could only find it on piers as i am posting this) that it Features: fuel pump, 10 micron filter, water seperator, includes fuel heater. kinda wanting a fuel heater was my only reason for previously wanting to keep the factory filter housing. unless piers and where ever else i read it was wrong i plan to remove mine.
Whoa ... do NOT re-think the FASS. You'll never find a better fuel supply pump anywhere .... PERIOD
You can either run the lines like I did in the link provided above, or if you'd like the FASS actuall DOES have ports that you can run lines to from your radiator to warm up the fuel.
So you see, FASS has you covered on all bases. I just chose a different path the heat the fuel,that's all. Get a FASS, I promise you you won't be dissapointed. :thumbsup
1998.5 24 valve 5.9 Cummins - Quad cab 8ft bed
4X4 -
FASS 150/95 -
Areo Turbine exhaust -
K&N intake -
Mag-tec Hy-tec trans and diffs -
3rd Gen 17" rims and caps -
Edge Comp Box - Various other mods
