Thread: Any Takers?
Old 01-16-2008, 11:53 AM   #3 (permalink)
92 buckboard
92 buckboard's Avatar
I will swap straight across for a complete stock suspension, a new moog track bar(this lift has a cool adjustable track bar with no ball joint on the upper end, just a bolt on both ends like the old 1/2 ton fords) a set of alloy 16x8 dodge wheels with some sort of tires on them and of course i will give the procomp tires and wheels as part of the deal.
92 clubcab 5 speed 4.10 gears, limited slip, slight pump mods. 98 quad cab 12 v long box 5 speed 3.54 gears limited slip 70 hp injectors, fuel plate, boost valve
92 buckboard is offline   Reply With Quote
