Old 01-16-2008, 02:01 AM   #35 (permalink)
dieselpower7.3
dieselpower7.3's Avatar
well most every diesel engine i see other then power stroke and duramax are in lines. i dont think i have ever seen a big rig with a v motor. i know there out there but i would think cat and detroit are more popular with the inlines. i beleive that inlines make more torque because of the strait up and downward force of the piston. if you where to take a twenty pound weight hold it over your shoulder and do push it up and down its a little harder to push up but comes down hard as well. well take a 15 pound hold it at a 45 degree angle from your chin and move it away from you and towards you. its a little easier to push away and doesnt wanna come back as hard. you change your weights because in a 6 cyclinder i would think that the piston and connecting rod as well as the counter weights are heavier then on a v8. ..... torque is a twisting force so the harder that piston comes down the harder the crank is going to turn.
06 qc 4x4 g56 edge juice hot unlock smarty sbc dd 3600 strapped centerplate no more chatter! htt 62.65.12 2nd gen manifold leveled 35's 6"single 487hp 990tq
dieselpower7.3 is offline   Reply With Quote
