Old 01-14-2008, 10:12 AM   #23 (permalink)
febrocks
The problems I had is listed below. It's really just fyi.
-fuel pressure sender bad. Leaking from signal posts. Do Not use sender that has rubber diaphram.
-If you run holley, it might leaking on bottom plate. Mine did on b100. Can't recall how long it took. I forgot when I installed it.
-3 plugged filters so far.
Good luck on your research.
Eugene
ps: the 24v will run on undercovered biodiesel. Don't ask how I know.
98.5 2500 slt, 24v,quad cab,2wd, longbed, auto. amsoil air filter, II stage 2 injector, VA V5, stock straight pipe, fass hpfp. FP/pryo/trans temp gauge.
febrocks is offline   Reply With Quote
