Originally Posted by mrl64
Hello, I am kindve new to this site, but I joined because I really have a problem that needs fixed with my truck... I have the Fass 150, along with a 9 month old Injection pump, 150 hp injectors, and superchips - edge comp. stacked.... What is happening is the truck runs fine at idle and at minimal throttle, but when I start into about half throttle or so when the truck is out of first gear and higher rpm's and boost (using more fuel) the truck starts to flutter like its starved for fuel... I thought it was the filters so I changed those.... that didn't fix it.... so I went to Columbus Diesel Supply where I got the pump and got a different spring to put in the pump to raise the pressure.... and that as well did not fix my problem... I kind've have an idea of what it could be but I just thought I would see if anybody has ever had those symptoms. I believe it could be my STOCK draw tube either too small, or clogged up.... any suggestions would be appreciated! Thanks, Matt
that is a common issue when stacking the edge comp and superchips, especially if there is timing involved in both. get rid of the superchips and buy a smarty to run on the FUEL ONLY settings
99' 2500 4x4, 6x12's, .093 tubes, Redline/Drag Comp, Prostreet 66/71/14, Studs/Orings/Head work by Woodruff, Hamilton Springs, Fass 150, Goerend/Suncoast Tranny by DPS
