With the DIY style setup running a pre turbo fogging setup at approx 1-2 psi is there a need for a regulator/converter to make sure you dont have liquid propane comming out the end of the hose? Does anyone know where to get a mounting bracket for a 20LB BBq tank?
2005 3500 HD 4x4 CDT auto/with custom TPS VB srw AFE stage II DDP injectors (70 hp )Quadzilla STD Rokktech sensor 4'' turbo back exh EGT Boost Trans guages 402 hp 749 tq on the 60hp setting w injectors
