Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 03-12-2008, 09:35 PM   #1 (permalink)
Grid heater delete FYI
Since everyone is worried about codes with grid heater delete, I figured I'd give you my $0.01 (so simple it's not worth $0.02).
The relay is located next to the passenger side battery (obviously you can see my intake). You will need to remove the wire from the grid heater as well as the wire from the battery. In the picture is how I had things when I first did the delete.The wire from the battery is just pulled back and zip tied. I now have the wires completely removed.
EDIT: Technically you will STILL GET CODES (or at least I have been) BUT it is not a "hard" code that triggers the CEL. It's P2609
If you leave everything like this you will be code free
But, if you want to remove the relay completely you will have to do some modifying...all one needs to do is connect the two wires (circled below, they are basically caps) together using a resistor. Carl48 told me any risistor between 14 Ohms and 20 ohms will work ...the truck doesn't actually know if the grid heater is working, only that the two wires from the computer have a current flow.
And, yes it is that simple
awenthol is offline   Reply With Quote
Old 03-12-2008, 09:56 PM   #2 (permalink)
Jpalmer's Avatar
How's the cold weather starting in Iowa without the grid heater?
2004 2500HD QC SWB 4X4, 48RE w/ shift kit, leveled on 325/65 Nittos & 18" Eagles, DS Predator, AirDog FP, CFM+ manifold w/ delete, Commander, QZ Boost Fooler, Airaid MIT w/ 4510, silencer ring gone, 5" exhaust, Line-X, and more...
Jpalmer is offline   Reply With Quote
Old 03-12-2008, 09:57 PM   #3 (permalink)
Wa. Chapter President
Austin The DieselTech's Avatar
When would it be a good idea to put the grid heat back in or can you do without it?
Austin Jenson - Napavine, Wa
477HP/862TQ - 2003 2500 6Spd QCLB 4X4 K&N, Gauges, SBC 3600 DD, Studs, HTT62/71/13SS, Flux 2's, Smarty, TST, AirDog 150, 6" Miters, rail capped
Austin The DieselTech is online now   Reply With Quote
Old 03-12-2008, 10:00 PM   #4 (permalink)
Even before I did the grid heater delete, i wouldn't wait for the heater to cycle, so I knew that the cold starting wouldn't be a problem. I've only had it on in the teens but the truck has started just fine. My original intentions were to put the delete on for the summer and run the heater in the winter but I don't think I will...or I'll see how it goes next winter and go from there...
Old 03-12-2008, 10:02 PM   #5 (permalink)
I keep my truck plugged in when it gets cold anyways so I prob could get away with leaving it out all the time.
Old 03-12-2008, 10:03 PM   #6 (permalink)
What do you gain from removing the grid heater? I talked to 04cummins a bit on the phone yesterday about it, he said he gained about 1 mpg. Why is this (this is my first dive into the diesel world)
CrAz3D is offline   Reply With Quote
Old 03-12-2008, 10:05 PM   #7 (permalink)
Well the grid heater is a restriction in the airflow into the engine. Unlike gas engines, diesels don't have throttle bodies to control air flow. They are open, so the more air you can get in and out the better.
Old 03-12-2008, 10:09 PM   #8 (permalink)
Ok, cool. Thanks
Old 03-12-2008, 10:10 PM   #9 (permalink)
Originally Posted by CrAz3D View Post
Ok, cool. Thanks
No problem. Glad to help
Old 03-12-2008, 11:38 PM   #10 (permalink)
Lineman954's Avatar
Yery nice! Thanks
I'm getting one as soon as there ready, but I'm not sure yet on leaving it on in the winter yet. It gets really cold here in Michigan. I see negatives numbers quite a few times in the winter
Ian
2006 2500 QC SB, 5.9L CTD, Auto, 4X4, SLT Bighorn, Patriot Blue, Muffler MIA
Power Lineman, I.B.E.W. LOCAL 876..Comstock Park, Michigan
Lineman954 is offline   Reply With Quote
Old 03-12-2008, 11:41 PM   #11 (permalink)
GIMME FUEL GIMME SMOKE
99cumminsho's Avatar
I love Florida HEHE. I think its 60* right know. Were could i get one besides spending $80 for the ones on EBAY?
1999 4x4, auto., 4:10 gears. With not enough power i gotta have more.
POWERED BY: FARM BOYS DIESEL
99cumminsho is offline   Reply With Quote
Old 03-13-2008, 12:07 AM   #12 (permalink)
I got mine from Glacier Diesel Performance for $60 but FarmBoys Diesel is making up a batch and he promises to sell them for less
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
