Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 04-25-2006, 04:11 PM   #1 (permalink)
Tech Specialist
Towtug's Avatar
*Attention*(2006 DH Trucks)
This is something I have seen about 4 or 5 times in the last couple months and I think this is going to be a TSB soon. I did get a tech report today telling the dealerhips ot be aware of the problem
The problem is on the 2006 DH Trucks, the vehicle may experince an intermintant NO START problem. If the vehicle sets for a while it may or may not restart. It will act as like a bad battery issue becuase some and most accessories will work but now start / no click.
The problem is the starter wire is grounding out. THis is what you need to look for and is fairly simple since most of us I think change our own oil.
With the hood up, there is a starting wire (YELLOW) with a connector in it, located up high running from the main harness to the battery. It is on the drivers side between the Battery and the Master Cylinder. What you need to do is look further down on the engine area at the starter and find the yellow wire again. Just above the starter is an engine crank case vent tube and is secured to the side of the block via a small loop bracket. The yellow starting wire on some of the DH Trucks is rubbing the above stated bracket for the vent tube. You will have to get under the truck to see that area just above the starter. You can simply zip-tie the wire away from the braket so it does not rub.
If it has been rubbing,it may need a wiring repair. If it has not been rubbing I would tie it out of the way anyway.
I am sharing this not to make anyone alarmed but just so next time you are changing the oil you might avoid a bad day in the future.
Im not the best at expaining things sometimes so if the above does not make since, ask any questions you might have.
JOSH
2006 CTD MEGACAB 3500 4x4 AUTO Towing my Rockbuggy from one state to the next...
Stop By And Vote For ROTM
Towtug is offline   Reply With Quote
Old 04-25-2006, 04:21 PM   #2 (permalink)
Tech Specialist
AK RAM's Avatar
Thanks for keeping us up to date on this stuff. This will be invaluable info as the 06's start to rack up the miles and the masses have had time to "rub". :thumbsup You're the man!
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Hot Cp3, Injectors, Cam, 315s, 8,200 lbs wet.
12.32 @ 109 Videos: Vid 1 & Vid 2
Add yourself to the Cummins Forum Map.
:thumbsup
AK RAM is offline   Reply With Quote
Old 04-25-2006, 04:39 PM   #3 (permalink)
UPNSMOKE's Avatar
We've Got One In The Shop Thanks For The Heads Up
SILVER 2002 ETC 3500 4X4, EDGE COMP, 4" STAINLESS EXHAUST, SCHWITZER S300G, EDM STAGE 4 INJECTORS, BHAF ISSPRO PYRO, BOOST, FUEL PREASURE GAUGES, A-PILLAR POD, 13" CONV. SOUTH BEND CLUTCH
479.1HP/889.6TRQ
SHE ONLY SMOKES WHEN SHE DRINKS
UPNSMOKE is offline   Reply With Quote
Old 04-25-2006, 04:58 PM   #4 (permalink)
Tech Specialist
Towtug's Avatar
There is a simillar issue I have seen with shorted trailer wiring. This is on the trailer side not the truck wiring. If this is the case you will more than likely get codes B166B, B166C, B166F, & B1670.
If you get the code DTC P1277 – Starter Control Circuit Low will be in TIPM. This is the one that will be the started wire I described on my first post.
Look for both with a no start no click issue.
JOSH
Old 05-17-2006, 01:41 PM   #5 (permalink)
Thanks for the info. Mine was slightly rubbing!
ridgeracing is offline   Reply With Quote
Old 08-13-2006, 08:57 PM   #6 (permalink)
2fishornot2fish's Avatar
JOSH
Whats the DH stand for?
01.5, 6 speed manual, 3/4 ton, Linex, 4" Rip Rock 4", tinted windows, Isspro:EGT, Boost, Fuel gauge, AFE Stage I, 3:55 gears, SMARTY
2fishornot2fish is offline   Reply With Quote
Old 08-14-2006, 08:41 AM   #7 (permalink)
Tech Specialist
Towtug's Avatar
DH is your 2500 and 3500's
JOSH
Old 08-14-2006, 04:27 PM   #8 (permalink)
COAL CRACKER
CTD610's Avatar
Thanks a lot!!! This will save some of us a lot of grief!!
2006 RAM 2500 QC SLT 4X4 - THUNDER ROAD PKG - CTD - 6spd - AEM Brute Force CAI-HURST T Handle
Old Truck: 2001 Silverado 2500 HD 4X4 Duramax/Allison
IBEW 1600
CTD610 is offline   Reply With Quote
Old 08-14-2006, 04:51 PM   #9 (permalink)
Tech Specialist
Towtug's Avatar
Yes Sir. No problem!!!
JOSH
Old 08-14-2006, 11:11 PM   #10 (permalink)
Tech Specialist/Super Moderator
TrueValue Truck's Avatar
:thumbsup gota love this site.....thanks for the info !
Caldwellfire.com
06 3500 SRW MC ,Smarty REVO,X2 Race stack, Commander,CFM, Monster Air COI,AFE Torque tube,FASS 150 HPFP LP,Muffler delete,Tipple disc Converter and VB ,ProComp 2" leveling kit,Timbren's,Reese Class V Tow Beast
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
