DIY Dash light bulb replacement - Dodge Cummins Diesel Forum
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
post #1 of 10 (permalink) Old 03-22-2010, 07:58 PM Thread Starter
First things first. Safety always. You are unhooking, unconnecting, and moving wiring so unhook BOTH negative battery cables. Chock wheels or set parking brake as you will have the truck out of park at one point.
1) Gather the parts. OEM part # 4839738AA QTY 10 per package (only way they sell them) $ 8.00 + tax = $8.69 for 10 bulbs.
2) Gather a few tools. Including a flashlight.
3) Remove single phillips screw from directly above trash bag hook
4) Pull on the hook and work your way around the trim piece. It is held on with clips and that one screw.
Now it should look like this. Do Not bother unhooking anything from this trim piece. Let it rest on the folded down cup holder.
5) Remove headlight switch assy. Grasp and pull. It is held on with clips only.
Same thing. Just let it hang there, no need to unhook it.
6) Remove TWO screws (stubby phillips) as indicated in picture. They are up inside these two holes at top of trim piece.
Grasp the bottom sides and firmly pull trim piece towards you as in picture below. Also is a great time to put the truck in Manual LOW (get shifter out of the way)
7) locate 4 screws (2 top-2 bottom) each corner that hold cluster. See pic below
Use a thin towell/rag and cover top in steering column so as to not scratch the face up on your cluster. Pull the left side outward first and access the plug on your left behind cluster (reach back there, its a little tight) then Pick up slightly on cluster, push bottom inward and pull top outward. It gets a little tight here to. Use the straight screwdriver to push in on connector lock and pry down with screwdrive popping connector out.
The connector on your left of the cluster you can reach behind and unhook. These connectors are what you are after.
This is the rear of cluster for a look at the location of your plugs.
Now the cluster is in hand, head to your favorite work place, lay down a nice towell, I do not suggest a bath towell if you are married, Sorry at this point you may need a laugh to go along with a few skinned knuckles.
These are what we worked so hard to get to. Now the smaller striaght screwdriver comes in handy to quarter turn and release the bulbs. Needle nose pliers to retrieve them.
NOW FOR THE MATH...... We have 11 bulbs in the cluster, but only 10 new ones. It was simple for me, rather then loose the new ones, I choose to put in all new, but had to guarentee 1 of my old ones was good. So the 12V cordless drill battery come out.
I find one old one that looks great, test good and put it directly behind the keyless entry reciever (THIS WILL BE COVERED IN THE KEYLESS ENTRY DIY), or whatever it is, the "hidden" bulb i am pointing to.
There you have it. Simple as pie. Put it back how you got it out and enjoy being able to see how fast you were going, or what temp you truck is running at.
2007 Ram 3500 Dually Bone Stock 5.9 Auto Long Bed
DOT2340390 MC799200
shakn03 is offline
The Following 13 Users Say Thank You to shakn03 For This Useful Post:
01cumminsred (03-22-2010), dieselfreak219 (08-18-2011), Flanman55 (03-22-2010), iowatwintz (10-09-2013), Jposey66 (11-30-2011), lalanscaper0485 (06-13-2010), nibroc (12-24-2014), nWilk666 (11-18-2013), rat4791 (03-22-2010), sconnors11 (06-12-2012), snAKes (11-11-2014), steve05ram360 (08-17-2012), Two03'Cummins (03-28-2014)
post #2 of 10 (permalink) Old 03-22-2010, 09:17 PM
Going to attack this tomorrow. Thanks for the great write up
2012 3500 Ram - Stock
Flanman55 is offline
post #3 of 10 (permalink) Old 03-22-2010, 11:37 PM
Awesome, thanks for the great write up with pics, I'll tackle this sooner than later now
'03 2500 LARAMIE CC/SB, 2.5" LIFT, 315/70-17, 4" MAGNAFLOW, QUAD COMMANDER, DS PREDATOR & EXTREME POWER PUCK, AIRDOG 150 + CAT 2 um, BHAF & GUTTED TORQUE TUBE, 47/48RE DTT TRANS WITH BILLET INPUT & FLEXPLATE
rat4791 is offline
post #4 of 10 (permalink) Old 03-22-2010, 11:56 PM
great diy............
but quick question on the heater controls........
do they use the same bulbs??
thanks for youe great post
40chevy is offline
post #5 of 10 (permalink) Old 03-23-2010, 12:31 AM Thread Starter
NO heater controls use 3 bulbs and are different. I will post the Dodge parts # in the morning when i return from dealer. They do however come out the same way, very simple 1/4 turn.
DOT2340390 MC799200
shakn03 is offline
The Following User Says Thank You to shakn03 For This Useful Post:
deacro (12-17-2011)
post #6 of 10 (permalink) Old 03-23-2010, 12:37 AM
thanks
you da man.......
40chevy is offline
post #7 of 10 (permalink) Old 03-23-2010, 12:40 AM
aclcummins's Avatar
great write up man. They should move this to the tech section so that i can find it easier later when i need to this.
2003 2500 4x4 graphite slt, lifted 6", 37" xtreme all terrains on 20x10 novicanes, amp research steps, rear air bags, isspro trans boost pyro, S&B Intake, FASS 150
aclcummins is offline
post #8 of 10 (permalink) Old 03-23-2010, 01:59 AM
leveled03's Avatar
very useful
Brian- 03 6 speed
leveled03 is offline
post #9 of 10 (permalink) Old 03-23-2010, 02:33 AM
Thanks man! Very detailed and great pictures. Will help out lots of people.
2003 Ram 3500 - SO, Smarty POD, Edge Juice w/att, Magnaflow 5", Volant Intake, BD exhaust Brake, 5" RC with extra 1.5" F+R, stock auto ---> 6 spd and SoutBend 3250DD
BigTree is offline
post #10 of 10 (permalink) Old 03-23-2010, 09:22 AM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
Moved to the 3rd gen tech articles
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
The Following User Says Thank You to JWH_03_Dodge For This Useful Post:
higpicker (06-12-2014)
