Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 03-01-2006, 04:07 PM   #37 (permalink)
OCD over the Cummins
PULN PWR's Avatar
Here is a link to the photo. I wonder if it is a S.O. vs. H.O. thing? Maybe the H.O.'s had that pump?
Cheers!
Chad
http://www.chad.prioritylabel.ca/Cha...ins%20(57).JPG
PULN PWR is offline   Reply With Quote
Old 03-04-2006, 06:02 PM   #38 (permalink)
Tech Specialist
my o4 305 has the cp3s
2004 305/555 6sp.DIY cruise control, 373's, bd short shift,homemade boost elbow,autometer boost and egt, isspro fuel press.,zenon flares,quad race box or sp diesel stage 1 stacked with diablosport predator, modded tone ring,bd pusher pump(and yes the truck still runs if the oem pump dies)afe intake and tt,sp diesel overboost eliminator,DIY modded cp3,
rich2500 is offline   Reply With Quote
Old 03-05-2006, 05:12 PM   #39 (permalink)
Tech Specialist
While you have it apart, can you measure the diameter of the plungers ? They will be either 6mm (roughly 1/4") or 8mm. Thanks.
In Cummins we trust.
'99 Ford Superduty CC with 05 Cummins 325/600, BHAF, Donalson M090544 and ZF6 transmission. Tone ring mod.
Walbro 392 lift pump. 2 micron fuel filter on engine with filter lid pressure gauge.
I've been running a Walbro 392 since 2000. How long did your fuel pump last ?
My diesel blog:
http://common-sense-diesel.blogspot.com/
Superduty is offline   Reply With Quote
Old 03-05-2006, 05:58 PM   #40 (permalink)
Tech Specialist
yes John I will try to remember to measure them for you,I will be taking more pics. also,I have the pump at my dads machine shop or I would measure them now.
Old 03-14-2006, 01:22 AM   #41 (permalink)
rockittboy's Avatar
super...if its a matter of programming between the 555 and 600's, shouldnt you be able to get your ECM reprogrammed for a lil more factory ECM controlled power before adding a box?
rockittboy is offline   Reply With Quote
Old 03-14-2006, 07:26 AM   #42 (permalink)
Tech Specialist
AK RAM's Avatar
Heee heee. Always looking for a free-bee. The injector tips are different as well. The spray pattern on the 600's is a little better and burns at a much higher BTU, generating a little more power. That and the ECM programming makes up the bulk of the difference.
I'm pretty sure the DRBIII will only allow them to install software that matches your VIN number. They can’t put any software program on any ECM. It just won’t let them. You would have to purchase one of the downloaders/programmers on the market to reprogram for more power. Besides, the 600 engines have the third injection event to keep the exhaust hot, which works with the cat to meet emissions requirements. That additional squirt of fuel at each revolution doesn’t make power, just heat, and brings their mileage down a little on average as compared to your 555. If you could do it, the cons would probably far outweigh the pros. A downloader/programmer might would be a better performer for you.
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Hot Cp3, Injectors, Cam, 315s, 8,200 lbs wet.
12.32 @ 109 Videos: Vid 1 & Vid 2
Add yourself to the Cummins Forum Map.
:thumbsup
AK RAM is offline   Reply With Quote
Old 07-06-2006, 01:19 PM   #43 (permalink)
Guest
Posts: n/a
They could, but they won't. EPA will only allow so many trucks to be produced meeting a certain emissions...changing the programming changes that number. I don't agree with this since reprogramming an older truck for newer emissions should actually be "better" as far as emissions are concerned. But the whole reprogramming is based on the EPA and the CAFE number a manufacturer must meet...one reason dodge titled the PT Cruiser a "truck".
At one point you could have a early 24-valve "reprogrammed" (around here) from 215HP to 235HP by a local dealer for around $150...they offered to do mine when it was in for tranny issues, but I declined. I don't think they will do that anymore, at least none of the locals talk about it. I don't know if it was really a reflash or what, just telling you what went down.
I have also heard that one of the TSBs for white smoke and poor performance of the early 600s was actually a reflash to a 610. I was told this was not the case at TDR, but a senior DC mechanic told me about this when I was in for a guage cluster issue (he needed to find out what TSBs had been done to my truck to know if he would need to reflash the new cluster)...again, just telling you what went down...
steved
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
