Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 01-28-2006, 03:18 PM   #13 (permalink)
Tech Specialist
Hi guys. I'm glad to see you.
Yep, you could put a sender in that hole or attach a remove gauge. I'll post pictures on how to do it with more detail.
I'm wondering if it would be easier to tap that hole NPT rather than ORB. Hmmm... let me give it some thought.
PM me before you actually do anything in case I have some tips from what I've learned.
In Cummins we trust.
'99 Ford Superduty CC with 05 Cummins 325/600, BHAF, Donalson M090544 and ZF6 transmission. Tone ring mod.
Walbro 392 lift pump. 2 micron fuel filter on engine with filter lid pressure gauge.
I've been running a Walbro 392 since 2000. How long did your fuel pump last ?
My diesel blog:
http://common-sense-diesel.blogspot.com/
Superduty is offline   Reply With Quote
Old 01-28-2006, 10:55 PM   #14 (permalink)
I love how you have the CAT filter mounted, but with all the talk of heat soak lately, do you think its a concern mounting the filters right there.
My dad has a good idea on the filter thing too. Why not mount the filters down on the frame rail somewhere, plumb the lines right up into the stock filter canister, but leave out the filter. Then you still maintain the stock fuel heater and you have the 2 mic filtration as well.
What do ya think about that ?
04 3500 SRW Quad Cab Laramie package,Deep Molten Red/Silver, BDPP/Edge EZ stack, BD RFI, Tone Ring Mod, Silencer Ring MIA, Gutted stock "torque tube", ISSPRO Pyro, Boost, Trans Temp, & FP gauges, GDP Walbro fuel pump kit...
99 Ford Ranger Trailer queen with too many mods to list
August 05 Mini Truckin Magazine Feature truck
043500QC is offline   Reply With Quote
Old 01-28-2006, 11:03 PM   #15 (permalink)
Tech Specialist
"I love how you have the CAT filter mounted, but with all the talk of heat soak lately, do you think its a concern mounting the filters right there."
That heat soak talk is rubbish. Sorry to be blunt. On the 94-97 Powerstrokes, the fuel circulated right through the head and back into the tank. Fuel doesn't pick up a whole lot of heat in the engine compartment.
"My dad has a good idea on the filter thing too. Why not mount the filters down on the frame rail somewhere, plumb the lines right up into the stock filter canister, but leave out the filter. Then you still maintain the stock fuel heater and you have the 2 mic filtration as well. What do ya think about that ?"
We all have opinions on filters. I think that 2 micron is too fine to run without a pre filter for it, so I run dual filters.
I also like the water trap, water in fuel indicator and fuel heater in the stock filter. The fuel heater should go before the 2 micron filter too.
My diesel blog:
Old 01-29-2006, 05:49 AM   #16 (permalink)
Guest
Posts: n/a
I run the Amsoil BE-100 single 2 micron
I have it mounted on the block below the turbo, there are a couple of bolt holes there and a ton of room.
Oil feed comes from the top of the OEM filter ( filtered side) then into the polish filter......so I get the 10 micron filtering then a 10% slip stream feeds the 2 micron polish filter
The return line comes up and into the oil filler cap where I have a swivel
Working very well for me too
Cheers, Kevin
Old 01-29-2006, 08:33 AM   #17 (permalink)
Tech Specialist
I think you are speaking of an oil filter. This is a fuel filter.
BTW: If someone is worried about the heat pickup at that filter, it could always be wrapped in insulating foam.
My diesel blog:
Old 01-29-2006, 08:38 AM   #18 (permalink)
Tech Specialist
honestly superduty that filter might need to be a little warm being two micron.....diesel gets kinda thick and gels up when its cold (not that i would know being in texas and all!) but a little heat might be just the ticket its not going to be enought to worry about but i would bet it helps that filter out a good bit .....just a thought ?
05 HO 325/610 The slipping G56 6 speed 4 door 4x4 3.73 long bed SLT Homemade torque tube/ airbox mod. crank sensor....homemade boost trick and 6 level fule control....more power than i have nerve!
smokin05 is offline   Reply With Quote
Old 01-29-2006, 09:27 AM   #19 (permalink)
Tech Specialist
I agree. Some people have come up with the argument that circulating fuel to the injection pump and back and/or running a filter like that or running a Walbro is going to heat the fuel too much.
I don't agree, but I don't have the energy to fight with people about fuel pumps right now.
My diesel blog:
Old 01-29-2006, 09:49 AM   #20 (permalink)
Tech Specialist
i certain understand the energy thing! i certainly dont think that your gonna get the fuel to hot? thats kinda out there considering where the fuel tank is located? under the truck where it stays pretty warm to begin with? you have to get diesel really really hot before there are any real issues... and its vented system so its not like the heat and pressure build in the system?
speaking of heat do you know anyone in the cummins family that has done a veg. oil conversion? i know some of my ol' 7.3 guys who have, but none w/ the hpcr ststem....the ford used the hpop to slam the fuel in, kinda different that the engine we have what are your thoughts? i am sure filtration and heat will be needed?
Old 01-29-2006, 09:52 AM   #21 (permalink)
Tech Specialist
You have to be very careful with using high viscosity fuels in constant displacement pumps (VE, P7100, VP44) because the pressures can get extremely high.
My diesel blog:
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
