| 3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING |
#73 (permalink) |
Illinois Chapter VP
what number fuse did you use for the jumper wire bkjeffery?
2006 Ram 2500 6 inch lift, 37' BFG MBRP stacks 6" Mitre tips, AIRAID intake, Raptor 150, AFE Bladerunner, MP-8,Smarty!, Why is there never enough time to do it right the first time, But always enough time to do it again? |
#74 (permalink) |
MS Chapter VP
I didnt use a fuse anywhere in the setup.......should I have???
04 QC/LWB 48RE 4x4: EJA, Arson CP3, BHAF, 4" TB stainless steel exhaust, 7" stack, Propane injection, Swanker intake manifold, GDP heater grid delete, BD 100 gal/hr pump, Big line kit, spin on fuel filter, Racor seperator, FS2500, mystery switch, 5 gallon on-board air system, Viair comp, Optima blue tops, 1875 Watt dvd stereo system, train horns. 6" lift w/35x12.50/20's |
#75 (permalink) | |
Illinois Chapter VP
#76 (permalink) |
Super Moderator/TECH SPECIALIST
For installation on 2007 5.9L with 48RE trans
If you are interested in completing this modification, and you have a 2007 truck, the first thing you will notice is you do not have relays in your under hood power center. You will basicly follow all the instructions for tapping the wire in the 7 pin round connector on the driver's side of the transmission. Pin #7, Color is Yellow with light blue trace, is the one you want. See previously posted pictures for clarification. Run the wire into the cab, and terminate your tap wire on one terminal of your normally open toggle switch. You then run a wire from the other terminal to Ground and terminate it. Note: If your switch happens to have 3 terminals, they may be labeled "C" for Common, "NO" for Normally open and "NC" for Normally closed, you will want the "C" terminal and the "NO" terminal. Disregarding any relay modification, you will substitute the installation of a 33 ohm 1/2 watt resistor in the wire that runs from the switch to ground. These may be obtained at Radio shack, a Pack of 6 cost about a dollar. You will only need one of the resistors. Cut the wire that runs from the switch to ground. solder or crimp in a 33 ohm 1/2 watt resistor. Insulate with electrical tape. You are now ready to test drive. Any questions on the 2007 installation, feel free to PM me. One final note:In case you feel "Uncomfortable" shorting terminals on a relay, and you own a 2006 or ealier 3rd Gen, you may substitute this 33 ohm 1/2 watt resistor for the jumper wire on the relay. It makes it a little simpler installation, nicer for removal in case of selling truck, and a little less "Noticible" modification. Thank you.
Bill Mish 2007 Dodge 3500 4X4/5.9L/48RE, KORE, SRT-10 hood, Recon, Isspro, ICEBOX/Amsoil, Walbro, SMARTY, FBD CFM+, FBD HGD, FBD 5" exhaust. FBD TC & VB 418hp/800tq |
