| 3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING |
#61 (permalink) |
that's where I have mine at 'the ground' but have you ever had the trans. not shift down into 1st with the switch off. mine will stay in 2nd or 3rd with the switch off, does not want to shift down when you come to a stop. other than that the lockup works.
78 John Deere 210, 1915cc VW |
#62 (permalink) |
check your connections, i dont know where you tapped the wire but check the plug at both the PCM (it will be the midle of the three) and at the trans
2003 3500 - HTS Billet Trans, Darkside Stage 4 CP3, SB66, TST, Smarty, RevD Custom Injectors, FASS 150/200, AFE, 5", Custom Paint 2000 2500 - Some Stuff |
#63 (permalink) |
is there a detailed walk through on this mod for the 05's?
[05 3500 5.9L CTD QC LB 4X4 AUTO SLT MINERAL GREY MET SPORT PKG] TORQUE TUBE GUTTED, SILENCER RING MIA, EDGE JUICE W/ATTITUDE + HOT UNLOCK, HAULMARK 119C REMOTE POPUP HITCH, ICEBOX COLD AIR INTAKE 4091 AMSOIL FILTER, PRO COMP EXTREME ALLOY SERIES 7189'S, LUND GENESIS TONEAU COVER, 2" LEVELING KIT, 200PSI TRIPLE TRAIN HORN, COOPER STT 33'S, BUSHWACKER POCKET STYLE FLARES, N-FAB NERFS. |
#64 (permalink) |
Anyone have the ATS Co-Pilot?
05 3500 Yellow 6 speed, Mega cab dually fenders, Rumble Bee Scoop, Edge Juice w/ A2, Striker 2, Valair 3600 DD, 5" Silverline exhaust, Icebox with torque tube, Rokkteck, Quad Rail Gauge, Mag-Hytecs, Brite Box w/ Fogzilla |
#66 (permalink) |
my "what it came with" from dodge state's I have a locking tourque converter.first time it did it I was idling around wally world in first. and I thought "oh,chit,bad tranny!. then it kind of popped out when I revved up to about 1800rpm(almost ran over a neon)what is the procedure for locking the converter if it already has one.?
2003 CTD HO short bed. 4*4 Laramie,leather, 48RE, Recons,running boards,EDGE-EZ,silencer ring removed,XDI Trueflow Intake,A pillar Pod,autometer pyro and fuel pressure gauges |
#67 (permalink) |
AFAIK none of the Dodges will lock the TC in 1st gear. You have to have a switch to do that (and maybe a modded VB on some years?). On the 06's it will lock in 2nd if you pull the shifter down, but I don't think most of the other years will even do that?
'06 3500 SRW Mega 4x4 - Prodigy, SPA Digital Gauges, Pioneer AVIC-Z1 DVD/Nav/Ipod/BT/TV/Cam, JL Audio System, Bilstein 5100's, 295 Toyo M/T's, Air Bags, 2 Way Alarm/Remote Start, Goerend Trans, Smarty Beta 4.4, MPI Twins, Flux 2's, 12.78 @ 105.5mph (No Smoke!) |
#68 (permalink) |
well I got It fixed and I'm glad to say it had nothing to do with the lock up or what I did while hooking it up. It ended up being the electrical solenoid or sensor I had changed them both while I had the pan off I guess they are know for going out and it make the truck not want to down shift into first gear. so just to let eveyone know that the lock up switch works just like it was explained. thanks to everyone that gave me some input on the problem I had.:thumbsup
#69 (permalink) |
Super Administrator
Six, did you jump the pin's in the fuse box?
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph) |
#71 (permalink) |
Super Administrator
Thank's Six, AK, and the rest of you here, very informative post. :thumbsup BRIAN
#72 (permalink) |
MS Chapter VP
Electrical Advice.
I installed the switch and it works without any Check engine lights or problems. It will kill the engine if engaged while stopped. When I hit the switch the trans automatically goes to overdrive and locks. This really lugs the engine when doing 25mph or less. Good for low speed coal rollin though. Heres what I did. I ran a wire from pin 7 on the 48re to a toggle on the dash then I ran a wire from the other side of the toggle to ground. I then used a jumper on the relay and re-installed the realy. Everything works good. If you take a 12V hot wire and touch it to a ground it will arc, if you hold it there the wire will get red hot in a few seconds. Heres my question. basically this is doing the same thing how come theres no red hot wires in this setup? Another question. If you wanted to use a 3 pole toggle with an led that lit up when the switch was activated how would you do it.
04 QC/LWB 48RE 4x4: EJA, Arson CP3, BHAF, 4" TB stainless steel exhaust, 7" stack, Propane injection, Swanker intake manifold, GDP heater grid delete, BD 100 gal/hr pump, Big line kit, spin on fuel filter, Racor seperator, FS2500, mystery switch, 5 gallon on-board air system, Viair comp, Optima blue tops, 1875 Watt dvd stereo system, train horns. 6" lift w/35x12.50/20's |
