Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 05-21-2007, 03:13 PM   #37 (permalink)
SIXINAROW's Avatar
Originally Posted by chuckger View Post
Yes you should be able to touch the wire to ground and have it lock up. Just so you know, the tranny will not allow lockup to engage in park or neutral, not even with the direct ground you have to be in gear. Check you ground and make sure you have a good solid ground.
Chuck
thanks for the reply, yea I had it in gear and tried it going down the road. My toggle has a led light in it and when you turn it on the light is on I'm getting power then when the truck locks the convertor in fourth gear the light will go off on my toggle switch so "I think" that is when the computer turns off the power to that wire witch activates the convertor. same as grounding the wire out I do understand that and how it is suppose to work but not sure why it does not. I have ground right to the battery just to make sure it was not the ground wire still nothing.
78 John Deere 210, 1915cc VW
SIXINAROW is offline   Reply With Quote
Old 05-21-2007, 03:24 PM   #38 (permalink)
kalkhokm's Avatar
The pins should be the same, as far as I know the only changes between years is the color of the wire you tap at the tranny.
As far as using the T.C. lock to launch, no you cannot use it for this purpose because if you lock it while you are sitting still it will kill the engine. It is like dropping the clutch in a standard while sitting still... A good time to lock the converter is at about 1500 rpm in second gear, it seems to be about the right power range in my truck. If you get good timing and you lock it at 1500 the truck just sits you back in the seat and pulls very hard al the way to 100 plus mph. Its awsome Be careful if you are running a stock tranny though, those locked shifts under high power are an input shafts worst nightmare!
Chuck
in my 99, the tc lock-up switch wont lock the tc until second gear, so if im at a stop (in first gear) i can flip the toggle switch and accelerate. when i hit second gear, the tc locks up and continues to do so into OD (wont lock in 1st). therefor i can launch with the lock up switch on.
99' 2500 4x4, 6x12's, .093 tubes, Redline/Drag Comp, Prostreet 66/71/14, Studs/Orings/Head work by Woodruff, Hamilton Springs, Fass 150, Goerend/Suncoast Tranny by DPS
kalkhokm is offline   Reply With Quote
Old 05-21-2007, 03:31 PM   #39 (permalink)
SIXINAROW's Avatar
that sounds cool Kalkhokm I bet you use it alot. I just took off my jump wire too see if that might do something no codes yet or check engine lights
Old 05-21-2007, 03:44 PM   #40 (permalink)
tractorpuller's Avatar
hmm, wonder if that would be the same on my 97. Have to try this.
97 extendedcab 4x4 auto;18*timing;SFS custom tuned afc custom ground plate;3k gsk; ISSPRO guages, 4" straight piped, bhaf, b&w gooseneck hitch, prodigy brake controller, kdp kia
tractorpuller is offline   Reply With Quote
Old 05-21-2007, 04:17 PM   #41 (permalink)
OCD over the Cummins
PULN PWR's Avatar
Sixinarow;
Sorry, a little off topic, but whos modded CP3 do you have?
Chad
PULN PWR is offline   Reply With Quote
Old 05-21-2007, 04:27 PM   #42 (permalink)
SIXINAROW's Avatar
I did it myself, drilled out some holes and cut a bigger notch out of the plunger I got the info from this site. seems to work good add's alot more fuel
"serious fuel considerations,... dual vs single" hope this helps
Old 05-21-2007, 10:59 PM   #43 (permalink)
any one do this on an 06 thanks
06 Flame Red 4x4 quad cab sb,30% tint,step bars,Recon clear cab lights,third brake light,Fass,Bully Dog,straight pipe,Superlift,35bfgs,isspro gauges,tst,ats flex plate,ats torque converter,full built trans,Van Aaken,more to come,Auburn IN
06FlameRed is offline   Reply With Quote
Old 05-22-2007, 06:42 AM   #44 (permalink)
PULN PWR's Avatar
Hahahaha, ya..... that was my post I started.
Thanks again!
Chad
Old 05-23-2007, 08:09 AM   #45 (permalink)
SIXINAROW's Avatar
anyone out there ever done a lock up on a 03
Old 05-23-2007, 09:44 AM   #46 (permalink)
feelmecummin's Avatar
i did my lockup...its an 03
mine is a delayed lockup though, i think its bc of my valve body
2003 3500 - HTS Billet Trans, Darkside Stage 4 CP3, SB66, TST, Smarty, RevD Custom Injectors, FASS 150/200, AFE, 5", Custom Paint
2000 2500 - Some Stuff
feelmecummin is offline   Reply With Quote
Old 05-23-2007, 06:04 PM   #47 (permalink)
SIXINAROW's Avatar
so yours works could, you tell me what I might of did wrong on mine I have a vb also
Old 05-23-2007, 06:24 PM   #48 (permalink)
Super Administrator
BBRam's Avatar
Hey Six, when you figure it out, I want one too.:thumbsup
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
