Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 05-17-2007, 05:24 PM   #25 (permalink)
kalkhokm's Avatar
lock up
Originally Posted by JaredMTFD View Post
Is there a way to do this on a '99? If so, could someone post a link to instructions, or explain it to me? Pictures are awesome, as well. thanks!
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
this takes about 5 minutes and very simple.
99' 2500 4x4, 6x12's, .093 tubes, Redline/Drag Comp, Prostreet 66/71/14, Studs/Orings/Head work by Woodruff, Hamilton Springs, Fass 150, Goerend/Suncoast Tranny by DPS
kalkhokm is offline   Reply With Quote
Old 05-18-2007, 08:13 AM   #26 (permalink)
OCD over the Cummins
PULN PWR's Avatar
Got a question in regards to the jumper on the relay.....
What purpose does this serve? Before I go and Giv'r, I want to understand what I am shorting out first.... LOL
Im just having a hard time getting my head around putting voltage somewhere it shouldnt be.
Chad
PULN PWR is offline   Reply With Quote
Old 05-18-2007, 09:47 AM   #27 (permalink)
chuckger's Avatar
Chad
What you are doing is causing a short on the 12v line that keeps the solenoid that controls lockup closed. When the voltage drops below 12v the solenoid opens and locks the T.C. If this happens any other time that the ECM expects it to happen the truck will show a check engine light and go into limp mode. By supplying voltage to the relay (with the jumper) the ECM never knows the T.C. is locked so it does not throw the code. If you don't short the relay you will only hurt performance not help. Don't worry about shorting that relay, it doesn't hurt anything:thumbsup Just make damn sure you get the right two pins, when installing the short!
Chuck
06 3500 4x4 Auto MegaCab 6" lift 37s on 20s AEM CFM+ 5" XZT II=
05 2500 4x4 Auto QC SB= R.I.P. VICTIM OF THE DEATH WOBBLE
87 Dodge Ramcharger 12 valve CTD Auto 10" lift 38" Boggers =
chuckger is offline   Reply With Quote
Old 05-18-2007, 09:51 AM   #28 (permalink)
PULN PWR's Avatar
Chuck
Ok, are the relay pins going to be different btwn the different years? Mine is an early 04 48re obviously.
Chad
Old 05-18-2007, 10:53 AM   #29 (permalink)
kalkhokm's Avatar
Im not trying to steal anyone thread but is the TC lock up switch safe to use at the strip/pulls when launching in 4wd?
(asked this in another thread and havent got any replies)
I am under the impression that (on 2nd gen 24v ) the switch only works when the truck is in drive, "D" and the OD has to be on. I cant imagine this being good for truck pulls w/ overdrive.
Old 05-18-2007, 11:45 AM   #30 (permalink)
chuckger's Avatar
Chad
The pins should be the same, as far as I know the only changes between years is the color of the wire you tap at the tranny.
As far as using the T.C. lock to launch, no you cannot use it for this purpose because if you lock it while you are sitting still it will kill the engine. It is like dropping the clutch in a standard while sitting still... A good time to lock the converter is at about 1500 rpm in second gear, it seems to be about the right power range in my truck. If you get good timing and you lock it at 1500 the truck just sits you back in the seat and pulls very hard al the way to 100 plus mph. Its awsome Be careful if you are running a stock tranny though, those locked shifts under high power are an input shafts worst nightmare!
Chuck
Old 05-18-2007, 12:33 PM   #31 (permalink)
Super Duper Moderator & Ontario Chapter VP
Ruckuz's Avatar
On my 96, you actually remove the relay, and only use the jumper wire.....
Anybody know when this changed??
1996 2500 4X4 Auto CC LB Banks Power Pack, Boost, Pyro & Oil Temp, 3k GSK, BHAF, #0 Plate Full Forward, Low Stall Triple Disc TC, TST Valve Body, Mystery Switch, Rancho RS9000's, MTX MZS1204'2/Alpine MRD M501, Viper Alarm & Remote Start, Dual 5" Grand Rock Turnouts, Rickson 19.5"s, and lots of stuff to make her look good.
Ruckuz is offline   Reply With Quote
Old 05-19-2007, 05:50 AM   #32 (permalink)
SIXINAROW's Avatar
well Puln-pwr did you try it yet or are you scared
78 John Deere 210, 1915cc VW
SIXINAROW is offline   Reply With Quote
Old 05-19-2007, 04:35 PM   #33 (permalink)
PULN PWR's Avatar
Just finished installing the ProStreet 66 stainless 16.....
GOTTA get that sorted out!
Chad
Old 05-20-2007, 11:24 AM   #34 (permalink)
SIXINAROW's Avatar
well I tried it, and on an 03 it's the orange/black stripe on it for the #7 pin. ran the new wire from the tap up and into the cab hooked it to a toogle switch then ran a wire from the toogle to ground. then put on the jump wire in the fuse box. well nothing does not work don't know what I did wrong not sure what to do to get it to work. looking for abvise. nothing else should'nt you be able to touch the two wire to ground and it should work wright or am I wrong. so help
Old 05-20-2007, 07:55 PM   #35 (permalink)
well i tried it today hooked the switch up and the wire to the trany then i was looking for the relay under the hood and as i can tell there is the relays on the 06 can any one help me thanks
06 Flame Red 4x4 quad cab sb,30% tint,step bars,Recon clear cab lights,third brake light,Fass,Bully Dog,straight pipe,Superlift,35bfgs,isspro gauges,tst,ats flex plate,ats torque converter,full built trans,Van Aaken,more to come,Auburn IN
06FlameRed is offline   Reply With Quote
Old 05-21-2007, 07:46 AM   #36 (permalink)
chuckger's Avatar
Yes you should be able to touch the wire to ground and have it lock up. Just so you know, the tranny will not allow lockup to engage in park or neutral, not even with the direct ground you have to be in gear. Check you ground and make sure you have a good solid ground.
Chuck
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
