Removing Shifter Knob (G56) - A - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 3rd Gen Tech Articles
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
Old 01-02-2007, 06:01 PM   #1 (permalink)
Tech Specialist
JWHPopeye's Avatar
Here is a little write up on removing the shifter knob on a G56 Tranny. Its really easy but i have a few suggestions to keep from tearing up your knob too much.
First thing i would suggest is do not try to pry out the middle piece by sliding screwdrivers in the sides. I tried this and it really messes up the knob. If you ever plan on reusing your knob or not, this is how i would suggest to do it, it made quick work on removing it.
1. First grab a drill, small drill bit and just about any screw. I used a decking screw that i had in the garage.
2. I drilled a small hole right in the middle to help get the screw started. Make sure your hole isnt too big the screw is going to strip the hole.
3. You can use either a screwdriver or a drill. I used a drill and screwed the screw in and it popped the middle piece right out.
(Yes i know, i just pretty much ruined the middle piece but i messed up the shifter knob even worse trying to pry the middle piece out. The middle piece shouldnt be more than $10-$15 to replace. The shifter knob on the other hand will probably cost a lot more if you want one thats not all tore up from trying to remove it.)
4. Once the middle piece is removed its straight forward. Use a 15MM deep socket to remove the nut.
5. Unscrew the shifterknob and its off.
06 2500 SLT, 4x4, SWB, Quad Cab, G56, SBDD 3600, Smarty Beta, Quad Boost Fooler, 5" FBD TBE-NO MUFFLER-NO DRONE , Amsoil 4510 and Torque Tube, Amsoil BMK-11, 315 BFG A/T's on H2's. WWW.PLAYINHOOKYSPI.COM
JWHPopeye is offline
Old 01-05-2007, 04:35 PM   #2 (permalink)
NOPLUGS's Avatar
where is the new knob i always had problems with the after maket ones wanting to turn all the time
2006 dodge 2500,4x4, 6 speed manual, southbend DD 3250, 4 door shortbed, bully dog triple dog downloader, boost fooler, whistler intake, silencer ring mia, 5" TBE, 315/70/17 on stock aluminium wheels powder coated black
NOPLUGS is offline
Old 01-06-2007, 09:57 PM   #3 (permalink)
Tech Specialist
JWHPopeye's Avatar
Hurst T-Handle Install - A
Here is the other thread showing the install of the Hurst T-Handle. So far no turning, i tightened the lock nut pretty tight.
Old 01-06-2007, 09:59 PM   #4 (permalink)
cashwheel's Avatar
That looks sharp,Had to get me one of them -12.00 on ebay, gonna order the SRT shifter from Tomeygun to go with it
04 - a few mods
cashwheel is offline
Old 01-07-2007, 03:15 PM   #5 (permalink)
Good wright up. I had no idea how to get the factory knob off.
05 4dr 4x4 G56 6spd dually, 35" MTZs, 5" straight pipe, Smarty/MP8, 2 probox 8s, JL 500/1, ranchhand legend front bumper, GDP performance 392, MK2+big line kit, tank vent mod, SBC sprung hub 3600 DD, Flux 2.5s, F1 springs, ARPs, BD R850s, Opie bypass.
wap13 is offline
Old 01-07-2007, 07:32 PM   #6 (permalink)
Dodgezilla's Avatar
iTrader Score: 16 reviews
There's got to be a better way to get the top off of the shifter. Did you check the service manual??
04 Ram 2500,Green/Silver 305/555HO,48RE,3:73s,QC,LB,4x4,Roadwire Leather Seats,Laramie Interior,Infinity Sound,HE351 Turbo,Custom 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan+180 Stat,Fogzilla,TRM,BFG AT 305/65s,72,000 miles
Dodgezilla is offline
Old 01-07-2007, 07:53 PM   #7 (permalink)
randyjinla's Avatar
to get the center out. i took a craftman pocket small flat screwdriver and slid it between the knob and center. and very carefully pried it up and out.
2006 3500 MegaCab 6-spd 5.9 Cummins
randyjinla is offline
Old 01-08-2007, 08:45 PM   #8 (permalink)
BCB
BCB's Avatar
I have used the back of the blade on a pocket knife several times and you can't tell. just takes the right tool and a little time.
BCB is offline
Old 01-12-2007, 11:13 AM   #9 (permalink)
NOPLUGS's Avatar
hey CASHWHEEL put up some pics of the srt shifter i bet that looks tough
NOPLUGS is offline
