Old 11-15-2008, 11:04 PM   #1 (permalink)
Strokin to Cummin!
Dreadnaught's Avatar
weird revving
i was kinda revvin my truck up in the driveway today (warmed up and was only hittin 2500 MAX) when the thing took off and wrapped up to 3300 rpm and stuck for a minute and came down VERY slowly. not quite sure what caused this, but the truck has been behaving normally since.
on a related note, when accelerating at 2200 rpm, the trans seems to hunt between 3rd and 4th then slams into lockup. it will go from 3rd, shift to 4th, the rpms will go up 75-100 and then it hits lockup. is there something wrong with it, or is this normal?
2004.5 Dodge Ram 3500 4x4 4 door, Short bed
Silencer MIA, Edge EZ
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler
Dreadnaught is offline   Reply With Quote
Old 11-16-2008, 10:25 AM   #2 (permalink)
Strokin to Cummin!
bump
Old 11-16-2008, 03:51 PM   #3 (permalink)
hey mine does the same thing when shes cold. . . you got an auto or a manual?
Red 04.5 H.O 2500 4x4 Cummins Regular Cab Long bed, 6 speed NV5600 , 4 inch turbo back exhaust 5 inch tip, 285/70/R17s on XD revolers. Dynoed 335Hp and 630 Tq. working on 101000 miles
oln608 is offline   Reply With Quote
Old 11-16-2008, 03:52 PM   #4 (permalink)
sorry just read the ur post over. . . cant help ya with the auto
Old 11-17-2008, 05:37 PM   #5 (permalink)
buzzinhalfdoz's Avatar
the 3rd gens are bad for surgeing while in cruise mode. the drive by wire is the other problem (it doesnt react like your foot would...). mine has done similar things...
03 2500 SLT 4x4 ,std cab,5 speed,volant air,flow muffler, quadzilla mpg mod,afe intake,1"taller tire,50hp sticks(OUCH),2-stroke oil,fitch.best 26 mpg empty,22 mpg 2000 lbs load,18-19 mpg pulling 5000 lb.240,000 miles now.10,000 between oil,original IP.25%wvo.
buzzinhalfdoz is offline   Reply With Quote
Old 11-17-2008, 05:39 PM   #6 (permalink)
twin64's Avatar
I believe the revving is due to building rail pressure, and then it doesnt drop off as soon as you let off. I could be wrong but its just a thought.
1996 2500 ext cab 4x4, built auto, 4K kit, 370s, Full Cut DVs, Gutted AFC, Homeground Plate, Homemade twins, 5" straight exhaust, Autometer guages
twin64 is offline   Reply With Quote
Old 11-18-2008, 02:22 AM   #7 (permalink)
green'97-12v's Avatar
mine does the same. if i rev it over about 2800rpms it will stay there for a couple seconds and then come down real slow.
'06 2500 QCLB, G56, EDGE, DIABLO, FASS, and some stuff missing
green'97-12v is offline   Reply With Quote
Old 11-18-2008, 06:17 AM   #8 (permalink)
MikeyB's Avatar
Yep, takes a second or two for the rail pressure to drop from high rpms.
MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Fogzilla mod, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, SMARTY, Lazarsmith Intake
MikeyB is offline   Reply With Quote
Old 11-18-2008, 01:42 PM   #9 (permalink)
I think there is a TSB out for tranny hunting for this year.
Engine rev sounds normal due to rail pressure.
Scott
2005 2500, Auto, TC lockup switch, RokkTech sensor, RokkTech muffler, Gutted chrome torque tube, Ram Snorkel on air box, Mopar cold weather kit. Pro Comp Extreme A/T 35's.
Nuttymopar is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
