Questions bout my build power goal of 800rwhp - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-15-2013, 06:19 PM Thread Starter
Addicted 06's Avatar
I have an 06 cummins auto trans that I'm saving to get built and like I said my goal is 800rwhp other than push rods valves valve springs head work and a cam what will my motor need to last. I'm gonna do some pulling but mostly a driver
06 2500 Firepunk stage 2, 100% over s&s injectors fleece 750 cp3 arp 625 EFI live by silverbullet fass 150 bean sump pump s&b intake , edge cts insight w get 33x12.50 20 trail grapplers and fuel maverick 20x10 2-piece
Addicted 06 is offline
post #2 of 9 (permalink) Old 12-15-2013, 06:21 PM
wwm
wwm's Avatar
I ordered my Firepunk trans last week.
I am going with a comp stage 1. Call and talk to Lavon @ Firepunk.
06 Cummins QCSB 4x4, Proline Diesel EFI Live, FirePunk, Flux 4s, PPE Dual fuelers, Fass 150, springs, studs, Thuren 2" on 35's. Steed with Twins 62/80
dyno # 947/1724
1994 RCLB 2x4, no plate, 4K GSK, S364, AFC mods, mercedes seats =)
wwm is offline
post #3 of 9 (permalink) Old 12-15-2013, 06:26 PM Thread Starter
I was looking at a garmons 2.5 trans how do they comparing?
post #4 of 9 (permalink) Old 12-15-2013, 08:53 PM
crf450x's Avatar
iTrader Score: 7 reviews
May want to consider rods at 800 too. That's getting pretty dang close.
'06 3500 G56 EFI Live, Dual CP3s, 75% Injectors, 68/83/.90
crf450x is offline
post #5 of 9 (permalink) Old 12-15-2013, 09:11 PM Thread Starter
What is a good brand of piston rods do y'all have good luck with
post #6 of 9 (permalink) Old 12-16-2013, 12:37 AM
vvvvv Chuck's Ride vvvvvv
Chuck Norris's Avatar
Carillo rods are one of the best.
2004 Dodge 2500:
OPTIMUS PRIME BUILD IN PROGRESS
Chuck Norris is offline
post #7 of 9 (permalink) Old 12-16-2013, 12:50 AM
First World Problems!
Kracken's Avatar
Consider a fluidamper or however you spell it? Also whenever going through an engine its nice to have it balanced as well since its all apart.
03 QCLB 3500 4x4
Friends don't let friends use II
798/1708
Originally Posted by CTDanger View Post
Your optimism is encouraging. Makes me want to catch and impregnate a unicorn.
Kracken is offline
post #8 of 9 (permalink) Old 12-16-2013, 09:32 PM Thread Starter
How much is to have the engine balanced and I guess it would be best to do it all at once?
post #9 of 9 (permalink) Old 12-16-2013, 10:29 PM
World Champs!!!
MoparProud's Avatar
Is the engine coming out? Like does it need repaired? If not, leave it in.
All you need is fuel (injectors and pumps) and air (turbos) and that's it. The engine itself doesn't "need" anything, other than head studs. Is a cam nice? I guess. Can't tell much difference with mine. Pushrods? Sure, if you're turning higher rpm. Valvesprings? Again, sure if you're turning higher rpm.
If it's in good running condition right now, I'd just do head studs, ~60-80% injectors (120-180hp), 64/71 over a 480, modded single or dual pumps, EFILive, lift pump, and a built trans. That's it. Boom there's your goal. Don't over complicate it.
And if you're turning it higher, do the pushrods and valvesprings.
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
