Old 08-31-2008, 06:35 PM   #1 (permalink)
Boost Fooler Question
Truck is in my sig. I see boost foolers are a cheap upgrade and was wondering what you guts think about them. Pros and cons. Thanks in advance for your replys.
White 06 5.9 SRW MEGA CAB 4x4, 6 spd,Laramie front bumper, muffler, converter and silencer ring MIA,SBC Con OFE
I'm just a bitter Amercian clinging to my religion and guns!
GrowinupMX is offline   Reply With Quote
Old 08-31-2008, 06:50 PM   #2 (permalink)
Smash n Grab
BILLS06's Avatar
They're just like adjusting the rod on manual waste gates, except it's in electronic form. Raises the stock kick out point from 34lbs to about 45lbs. I'd get a boost gauge to monitor the situation.
06 QCSB Capped Rail Airaid Baffle Delete MagHytec Transmission Pan Aeroturbine Muffler Fluidampr Superchips Pyro/Boost & Autometer Ultra Lite Digital Oil Pressure & Transmission Temp Gauges ATS 5 Star TC Flexpiped CAT DDR Enabled Royal Purpled EZ Down Weston Nerf Bars Spray In Bed Liner Valley Gooseneck Hitch
BILLS06 is offline   Reply With Quote
Old 08-31-2008, 07:14 PM   #3 (permalink)
Arizona Chapter VP
kgeiger81's Avatar
I had one on my truck for a while before I put a downloader on it and I didn't notice any increase on the boost gauge. After the downloader was put on it jumped the boost up to 45-46 lbs. However you should be careful running the stock turbo that high cuz their not really designed to boost much over about 34-36 lbs from what I'm told. Which is why I took it off.
'07 2500 5.9L, K&N intake, Magnaflow exhaust, Cat and silencer ring MIA,
Autometer Phantom II's, Bully Dog Triple Dog, B&W Turnover Ball
My old truck: 1999 Dodge 2500 CTD myspace ACDC
kgeiger81 is offline   Reply With Quote
Old 08-31-2008, 07:19 PM   #4 (permalink)
Very good info guys. I am tryin to learn all I can. Thanks:thumbsup
Anyone else?
Old 09-01-2008, 08:58 AM   #5 (permalink)
RRAMctd's Avatar
I notice when running it I get lower egts climbing hills and such. I run my programmer on extreme and it creates alot of egts. So it helps in my case. On the downside I get much more turbo bark or wastegate dumping sound with on when I am not careful, I noticed it much more now that I have a new low stall TC.
Reg
05 3500 Larmie 4X4 Q/C Long box Single axle Diablo Predator,Boost Fooler AFE stage II, Isspro guages pillar mount, Cat gone, DynoMax muffler, shift kit, Revtec leveling kit, Billet low stall TC
RRAMctd is offline   Reply With Quote
Old 09-01-2008, 09:16 AM   #6 (permalink)
lobsterman04's Avatar
With the sticks(injectors) i notice a difference when i unplug the fooler. but i honestly didnt notice a dif stock till i raced my buddies 01 identical to mine. I slowly pulled away but i still won. works good till you get a programmer. then they are pointless.
99 2500hd quad cab long bed,4.10, white n grey 2tone. BHAF, 4in custom stack with rain cap and heat shield, boost guage,airdog150, 150sticks, Adrenaline!. soon an s300! THANKS TO COAL TRAIN DIESEL PERFORMANCE
lobsterman04 is offline   Reply With Quote
Old 09-01-2008, 12:56 PM   #7 (permalink)
Stock boost limit is about 20 psi.
RRAM, you are not hearing the wastegate open!! Possibly is turbo surge.
j-fox is offline   Reply With Quote
Old 09-01-2008, 08:43 PM   #8 (permalink)
RRAMctd's Avatar
Well whatever it is it is annoying, and I get more of it with the fooler. I was getting pretty good at driving around it till I put the fooler back on and now have to learn to drive again. or take it off.
As far as it not being needed with a programmer that is wrong. It is needed with my programmer, which has no boost fooling built in, only tons of awesome power and smoke.
Reg
Old 09-01-2008, 08:47 PM   #9 (permalink)
MAD_CR06's Avatar
your stock turbo is good for about 35 psi. anything after that your just pushing hot air and doing no good.
RIP06 2500 Qaud cab 6spd, Autometer C2 Fuel pressure, Boost, Pyrometer, Quad railpressure gauge, Smarty, Southbend DD, CFM+, AFE mega-cannon,ATS manifold, Silver 62, 5" MBRP turbo back, FASS 150, 506hp 1047tq on 35X12.50X20R. Thanks to Truck Source Diesel.
MAD_CR06 is offline   Reply With Quote
Old 09-07-2008, 05:39 PM   #10 (permalink)
chefbutthead's Avatar
Boost Fooler
I put a quadzilla boost fooler on my 07 2500 for about three days. I noticed that there was no smoke coming out of the exhaust when I got on it. The thing did not give me any more power than the superchip did and after I took it off, the truck did not have as much power and the fuel economy got worse.
Has anybody had this experience with the boost fooler?
thanks,
chefbutthead
07 Dodge 5.9 Cummins Diesel Superchip and stock until the warranty runs out at 75000 miles
chefbutthead is offline   Reply With Quote
Old 09-09-2008, 05:44 PM   #11 (permalink)
i am looking at one too but i am afraid it hurts my turbo. How bad can this really be for your stock turbo? i dont want to be blowing anything up but i want more power. it seems like a cheap upgrade
04.5 cummins, green intake, bully dog w/ crazy larry, 5" straight pipe, bd flex plate, ats tc, vb, input shaft, raybestos clutches transtech rebuild kit, and lots of chrome. NEED MORE!!!!!!!
JR's04Cummins is offline   Reply With Quote
Old 09-09-2008, 06:08 PM   #12 (permalink)
Arizona Chapter VP
kgeiger81's Avatar
thanks,
chefbutthead
The truck is already fueling to componsate for the amount of boost the wastegate will allow. The boost fooler does not increase fueling, it basically allows the turbo to exceed the stock boost levels by altering the pressure reading from the MAP sensor, however you will not see a difference until you install something on the truck that will allow it to fuel over the stock levels. Keep in mind anything over 34-36 psi the turbo is basically pushing hot air which will result inhigher EGT's and premature turbo failure. Hope this helps...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
